04-18-2001, 15:00 | #2 (permalink) |
No Life Poster Join Date: Oct 2000
Member: 2274 Status: Offline Thanks Meter: 0 | You must tell us more! What a phone? What you did with phone! There can be many reasons for "Contact Service". Some yu can repair with Dajan! Contact me per mail! I will help you! Greetings MR... |
04-25-2001, 23:03 | #5 (permalink) |
Freak Poster Join Date: Feb 2001 Location: Canada, Montreal
Member: 3248 Status: Offline Thanks Meter: 2 | hi can we fix 6210 contact service with nokia flasher. i bought a nokia 6210 with contact service at a very cheap price to take from it parts i decide to learn on it how to fix the contact service can naybody tell me how to fix this problem???? is it by flashing the phone full flash? thnx bye |
04-26-2001, 00:29 | #6 (permalink) |
Junior Member Join Date: Apr 2001 Location: Portugal
Member: 3937 Status: Offline Thanks Meter: 0 | Hi everyone! I have the same problem, I full flsh my phone (3310 4.02) (0020000-00330000) and now it says: "CONTACT SERVICE", what should we do? Tkhs in advance CyberMania [email protected] |
04-26-2001, 03:41 | #7 (permalink) |
Freak Poster Join Date: Jan 2001 Location: 13 00 N, 122 00 E (PH)
Member: 3156 Status: Offline Thanks Meter: 63 | hi guys, u know the easiest way to repair a CS unit is to; FIRST and foremost, backup the entire eeprom area if the phone has an emulated eprom (u'll find the info on adresses somewhere in the forum) and save it somewhere real safe. next, just full flash it with THE SAME firmware and ppm version. so when it says 4.19 euro, flash ONLY with 4.19 euro (copied from a GOOD and WORKING phone). next step is to upload the eprom part e.g for 3310 v4.02 u write eerom from add: 003D0000 and if the phone has no hardware problem at at all --- it will be alive and with network! otherwise, read more on how to repair broken unit (esp 3310) located somewhere in the forum. for units like 32 and 51, its another story -- read above! note: u dont have to remove the 24cXXx u can read and write on it in-circuit just be carefull when soldering wires or much better use super-tiny ic clips. dump eprom content and repair using bartek or guars checksum repairer, save and upload back to d phone -- u have it! and sometimes u need to do a full flash (same rules apply -- same version and ppm) |
CONFIG KEY: 0000000000000000 is there any way to repair this! | ATSC L.L.C | Universalbox | 8 | 03-20-2009 09:17 |
CONFIG KEY: 0000000000000000 is there any way to repair this! | ATSC L.L.C | J.A.F. By Jafsupport.com | 0 | 01-21-2009 14:04 |
Is there any way to repair imei on M6100? | Burnt Cobba | VygisToolbox | 3 | 11-25-2007 21:28 |
Damaged solder pads ? Is there any way to repair them ? | simbirley | Nokia Hardware & Hardware Repair | 3 | 01-21-2003 20:27 |
Is there any way to repair "Contact Service" Using Dejan Flasher | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-19-2001 22:08 |
