Is there any way to repair "Contact Service" Using Dejan Flasher Is there any way to repair "Contact Service" Using Dejan Flasher.? |
It entirely depends on what unit you have, and which part is causing such error. 1. If it is "hardware", then you have to fix it electronic wise. 2. If it is an EEPROM problem, you can only use Dejan flasher on units that have EEPROM emulated in flash (i.i 3310, 6210, 7110). If not (like 5110, 3210, etc), then you need a separate hardware to extract EEPROM contents then repair the file. 3. If it is an MCU or PPM data corruption. Regards, aCe ;) |
Hi frends, Contac service phone check m-bus cable phone must be on start wintesla open pruduct on startup self test mmpruduct failed (ccont,mcusw,eeprom v.b)flash checksum failed start dejan flasher and full flash phone is ok... Quote:
Simlockboy http://www.volkangsm.4t.com :) :) :) <FONT COLOR="#ffff00" SIZE="1">[ 18 April 2001 20:03: Message edited by: volkangsm ]</font> |
Hİ, ıf you dejan flasher full flash updated no repairer contack service please see this steps; you know password e2p and flash and mcu wintesla no say this pass you updated flash+mcu your phone http://electroboys.freeservers.com http://gsmunlock.da.ru |
