Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 04-18-2001, 14:06   #1 (permalink)
Administrator
Member: 3188
Thanks Meter: 2,390
Lightbulb Is there any way to repair "Contact Service" Using Dejan Flasher
Is there any way to repair "Contact Service" Using Dejan Flasher.?
__________________
Old 04-18-2001, 18:46   #2 (permalink)
Member: 3165
Post
It entirely depends on what unit you have, and which part is causing such error.
1. If it is "hardware", then you have to fix it electronic wise.
2. If it is an EEPROM problem, you can only use Dejan flasher on units that have EEPROM emulated in flash (i.i 3310, 6210, 7110). If not (like 5110, 3210, etc), then you need a separate hardware to extract EEPROM contents then repair the file.
3. If it is an MCU or PPM data corruption.
Regards,
aCe
Old 04-18-2001, 19:02   #3 (permalink)
Member: 4121
Thanks Meter: 11
Hi frends,
Contac service phone check m-bus cable phone must be on start wintesla open pruduct on startup self test mmpruduct failed (ccont,mcusw,eeprom v.b)flash checksum failed start dejan flasher and full flash phone is ok...
Originally posted by AboAli:
<STRONG>Is there any way to repair "Contact Service" Using Dejan Flasher.?</STRONG>
Best Regards,
Simlockboy http://www.volkangsm.4t.com
<FONT COLOR="#ffff00" SIZE="1">[ 18 April 2001 20:03: Message edited by: volkangsm ]</font>
Old 04-19-2001, 22:08   #4 (permalink)
Member: 658
Red face
Hİ,
ıf you dejan flasher full flash updated no repairer contack service please see this steps;
you know password e2p and flash and mcu wintesla no say this pass you updated flash+mcu your phone
http://electroboys.freeservers.com http://gsmunlock.da.ru
CONFIG KEY: 0000000000000000 is there any way to repair this! ATSC L.L.C Universalbox 8 03-20-2009 09:17
CONFIG KEY: 0000000000000000 is there any way to repair this! ATSC L.L.C J.A.F. By Jafsupport.com 0 01-21-2009 13:04
Is there any way to repair imei on M6100? Burnt Cobba VygisToolbox 3 11-25-2007 20:28
Damaged solder pads ? Is there any way to repair them ? simbirley Nokia Hardware & Hardware Repair 3 01-21-2003 19:27
Is there any way to repair "Contact Service" Using Dejan Flasher.? AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 04-26-2001 03:41
Page generated in 0.22807 seconds with 8 queries
