02-05-2002, 22:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8030 Status: Offline Thanks Meter: 3 | Upgrade 7110 from 4.88 to 5.01 BUT i seem to recall seeing some posts somewhere about there being a problem about the 5.01 mcu+ppm overrunning into the eeprom area by a couple of bytes and the updates therefore not working. Anyone got any idea if this is true - or do i just need to flash the 5.01mcu+ppm into my 4.88 phone and then do a FAID calc as normal? Regards, Northernbloke |
02-06-2002, 02:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: London Age: 49
Member: 7939 Status: Offline Thanks Meter: 2 | Do back-up then do upgrade, the problem is with the 04.84 and lower soft version phone's, so if all does go wrong you have back-up to flash back, also back up eeprom as a new file as well so you could flash first if you have any problem. <img src="biggrin.gif" border="0"> |
02-06-2002, 17:51 | #4 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Czech Republic
Member: 4246 Status: Offline Thanks Meter: 9 | Hi,<br />better reset the phone BEFORE flashing and updating.<br />You can reset it with NokiaTool or write *#7370#+security code.<br />And after update FAID reset the phone,too.<br />regards |
02-07-2002, 21:46 | #5 (permalink) |
Member: 8030 Status: Offline Thanks Meter: 3 | wow - was just about to go flash it when i saw a post on here about logging and it says the flash i have downloaded from brads site (v5.01) is already partially unlocked therefore logs don't work. <br />Can anybody confirm this and if it's true where else can i get a v5.01 mcu that isn't partially unlocked??? Regards, Northernbloke |
02-07-2002, 22:19 | #6 (permalink) |
Member: 4246 Status: Offline Thanks Meter: 9 | I can send you my own made 7110 5.01I:NOT partially unlocked.<br />So it works ok.<br />Mail me your requests.<br />regards <FONT COLOR="#ffff00" SIZE="1">[ 07 February 2002 22:20: Message edited by: mudboy ]</font> |
02-10-2002, 16:38 | #11 (permalink) |
Member: 8030 Status: Offline Thanks Meter: 3 | Well - I tried and failed to upgrade it. mcu + ppm D flashed ok but when phone is restarted it gets past insert pin and stays on the startup screen for about 20 seconds before switching off (not like normally happens with phone resetting when FAID calc needs doing - it goes off and stays off) managed to log it using B-phreaks new logger (at about the 10th attempt - got log calculated and updated the phone but still not working. Flashed my backup and all ok back to the drawing board methinks. Regards, Steve H - cheers again for the mcufile mudboy - i'm sure that it's ok and not the cause of the problems - got to be something else |
02-13-2002, 02:38 | #12 (permalink) |
Junior Member Join Date: Jan 2001 Location: UK
Member: 3085 Status: Offline Thanks Meter: 0 | Ive had two of these 4.88 swines in and I too cannot update the mcu+ppm without the same problems of hanging and resetting, even stranger than this if I try to read any 5.01 to make a working mcu its always reported as bad mcu and obviously is unusable but the phones with 5.01 work without fault. CW |
02-13-2002, 20:35 | #13 (permalink) |
Member: 8030 Status: Offline Thanks Meter: 3 | what are you using to read the phones and create the mcu CW. I get this message constantly on Rolis 477 and 5.14 on 6210s and 7110's when i read the full flash. I do use it for writing though cos it's much quicker than KnoK. I use KnoK for making full backups now never had a duff read yet on it. Have u tried just reading the MCU or PPM or EEprom area seperately using the relevant addresses instead of using a full read and letting the sw split it up for you? |
02-20-2002, 22:29 | #15 (permalink) |
Member: 3085 Status: Offline Thanks Meter: 0 | Hi NORTHERNBLOKE Yes you are correct I use rollis 4.77 and nokiaflasher tool 1.1 by our freind Cyberdog and both produde error in mcu so i will try this Knok program but where do I find it looked everywhere but no joy. I also have been told that after mcu+ppm upgrade to 5.01 you must reset like MAK_US1977 says with wintesla or 6210 security code reset ver 1.2. I will give it a go later and post result. CW <img src="cool.gif" border="0"> |
After upgrading 6280 from 3.70 to 5.92 phone won`t go to test mode any more! | robbie | HWK | 8 | 10-17-2006 10:34 |
Flash 3310 under Win2000 from 4.19 to 5.55 | Geldhai | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-12-2002 17:44 |
7110 4.88 > 5.01 Problems | Spammy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-22-2002 22:33 |
7110 upgrade from 4.73 to 5.01 | devilboy1488 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-11-2002 07:11 |
Solution to upgrade 7110 from 4.84, 4.88 up to V5.01 | banKa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-02-2002 09:34 |
