03-10-2002, 23:27 | #3 (permalink) |
Freak Poster Join Date: Nov 2001 Age: 45
Member: 7327 Status: Offline Thanks Meter: 12 | here is breif description from b-phreaks hello m8 to make sure that IMEI number and IMEI_Programing Data are valid. Insert a working SimCard in the phone, switch it on and tick the TEST DSP check box. Logger will put the DSP in test mode and will start continious reading of one of the ADC's in COBBA - this will show the RSSI Value in the status bar. If everything ok - you will get a reading for about minute and at the end of the test you'll see message : DSP Test OK ! If anything wrong - Message Box will propmpt that you have bad responce from the DSP. This will happen when: - IMEI or IMEI_program data - corrupted - AuthorityID not valid - RF part is faulty ( hardware fault ) - Missing Ariel or no Cell coverage This Test is not 100% reliable - so make sure that all other reasons are excluded. You need to have a SimCard in the phone ! Good idea is to make this test few times - between tryes reset the phone to full factory and switch it off and on again. kind regards . |
What Is Jtag?-joint Test Action Group-fag | aikonmani | GSM Programming & Reverse Engineering | 49 | 10-10-2014 14:20 |
What is version new Test Point SX1? | controllerz | E-Gold Based Phones | 1 | 07-14-2005 22:46 |
What the USB connectors for ?on UFS-3 | fadi3 | UFS2 + UFS3-Tornadoflasher | 4 | 05-28-2005 19:21 |
Patriot clips on stock, just tested also on the newest V70e | Raskal | Main Sales Section | 8 | 08-22-2002 10:23 |
