Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 10-06-2001, 13:33   #1 (permalink)
Moc
Member: 6099
Post Work only 20 min aprox. - 3210
Hi all
Which is the solution for nokia 3210 which work only 20 min. aprox. ...the battery is ok ???
Rgds
Old 10-06-2001, 15:38   #2 (permalink)
Member: 2628
Post
I need some more information, what are working about 20??? The phone ok what happen after. Check the contacts to the phone!!
<br />Good luck!
Old 10-06-2001, 16:28   #3 (permalink)
Moc
Member: 6099
Post
Hi Zizo
The phone workin very well until 20 min aprox. after that go down .....the battery , conection all this is ok....i thing is hardware problem , so any soluction for this .....
Rgds
Old 10-07-2001, 06:36   #4 (permalink)
Member: 5971
Thanks Meter: 2
Post
hi moc.<br />if the battery is ok how about your charger?<br />is this the charger you use that of 7110?
Old 10-07-2001, 14:27   #5 (permalink)
Moc
Member: 6099
Post
Not solve, i will reflash the phone ...it is good idea ? Or is hardware problem ?
Rgds
Old 10-09-2001, 12:53   #6 (permalink)
Member: 2628
Post
Try to flash the phone but do not forget to take a "copy" on ur phone before the flash!!
And sorry that I was late with the answer!!
<br />Good luck
Old 10-09-2001, 12:55   #7 (permalink)
Member: 2628
Post
Check the contacts once again before the flashing!! Check the components around the contacts also!!! before
<br />Good luck
j230 speaker works only 10 mins j_prakashh Sony Ericsson Hardware Repair 0 10-25-2008 17:31
3210 working about 10 mins, and then loses network... dimka Nokia Hardware & Hardware Repair 2 02-28-2002 08:43
Work only 15 min Moc Hardware Repair by brands 0 09-02-2001 11:26
3210 - only 20 seconds working GSMWolf Nokia Hardware & Hardware Repair 5 07-27-2001 16:06
3210 - only 20 seconds working GSMWolf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 07-26-2001 12:21
Page generated in 0.44634 seconds with 9 queries
