Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
03-19-2009, 10:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 759168 Status: Offline Thanks Meter: 12,866 | 1200 1208 and 1650 ???????????? solution [.imei patch] 1-put PATCH in MCU. 2-PPM and CNT asuaual (Ver 4.11)must. 3-Tick on UI and UNLOCK options. 4-When unlock patch ask file, give same patch which use in MCU. 5-Tested on 1200 1208 and 1650. http://rapidshare.com/files/132846998/Patches.rar |
The Following 13 Users Say Thank You to samirov-gsm For This Useful Post: |
03-19-2009, 11:58 | #2 (permalink) | |
No Life Poster Join Date: May 2007 Location: Shoaib Electronics
Member: 515273 Status: Offline Sonork: 100.1573940 Thanks Meter: 339 | Quote:
This patch is use for imei change not imei currupt ????????? Imei currupt is solve to using ASK2RPL service | |
The Following 4 Users Say Thank You to dil_PAKISTANI For This Useful Post: |
04-06-2009, 04:11 | #6 (permalink) | |
Freak Poster Join Date: Apr 2005 Age: 45
Member: 142172 Status: Offline Thanks Meter: 55 | Quote:
if the imei is like this ???????????????, you need buy rpl. dont post this, is not true........ | |
04-06-2009, 09:43 | #7 (permalink) | |
Freak Poster Join Date: Sep 2004 Location: PAKISTAN
Member: 82446 Status: Offline Thanks Meter: 41 | Quote:
in this way u can change only ime. If ime is crupted . In this way its ok but signal not found | |
The Following User Says Thank You to younas For This Useful Post: |
07-21-2009, 15:54 | #10 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Punjab India
Member: 687144 Status: Offline Sonork: 1614780 Thanks Meter: 228 | 1208 [QUOTE=samirov-gsm;4262752]1200 1208 and 1650 ???????????? solution [.imei patch] 1-put PATCH in MCU. 2-PPM and CNT asuaual (Ver 4.11)must. 3-Tick on UI and UNLOCK options. 4-When unlock patch ask file, give same patch which use in MCU. 5-Tested on 1200 1208 and 1650. it is ok solution but after some time mobile set off ..it is problem |
The Following User Says Thank You to Maninder_111 For This Useful Post: |
09-15-2009, 08:26 | #12 (permalink) |
No Life Poster Join Date: May 2009 Age: 49
Member: 1027729 Status: Offline Thanks Meter: 97 | Getting MCU ID MCU ID: 0x2292 FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Searching for default location of ini... Checking path: \Products\RH-99\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Scanning ini files... Checking path: \Products\RH-99\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.91aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.91aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... Error Auth! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... MCU ID: 0x2292 Reading flash chip detailes... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Error erasing area: 018F0000 - 018FFFFF Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD Error booting phone... MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Error erasing area: 01010000 - 0101FFFF MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Searching for default location of ini... Checking path: \Products\RH-99\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Scanning ini files... Checking path: \Products\RH-99\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.91aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.91aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... Error Auth! help me after patching and edit imei |
09-16-2009, 04:05 | #14 (permalink) |
Junior Member Join Date: Feb 2008
Member: 714101 Status: Offline Thanks Meter: 0 | JAF version 1.98.62 Detected PKEY:EXTREME_CSC Card life counter: 54.83% P-key nokia module version 01.02 Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.8.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.11ej CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Russian,Ukrainian Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.11ej CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai4.11ej ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Russian,Ukrainian Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: A9 7E B2 1A 1B BE 0B E2 79 58 6B E4 DB EE 61 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 8490DD5FEDA2A2461682F3240E MSID decoded: 3E4EBAE9005F4B85A9000000 FAID: 8BBA364576790F369075B350 Operation took 0 minutes 16 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 31 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 13 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.11ej Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: A9 7E B2 1A 1B BE 0B E2 79 58 6B E4 DB EE 61 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 845CA632296C80AA892FC5C96C MSID decoded: 3E4EBAE9005F4B85AA000000 FAID: 0A7921C78107EA9E5FA2E198 Operation took 0 minutes 16 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 9 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 7 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai4.11ej Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 8490DD5FEDA2A2461682F3240E MSID decoded: 3E4EBAE9005F4B85A9000000 FAID: 8BBA364576790F369075B350 Operation took 0 minutes 16 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 0 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Flashing Done! Operation took 2 minutes 30 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-105, Software version: 4.11 IMEI: ??????????????? Product Code: Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 7 seconds... Done! Done! Powering the phone... Unlocking... IMEI: ??????????????? ASIC: b SW version: 4.11 Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 02 MCU ID: 0x2292 Algo is ready... P-key nokia module version 01.02 Erasing area: 011E0000 - 011FFFFF... Erasing area: 011E0000 - 011FFFFF... Unlocking... Simlock data rejected! Code: 0x13 Failed! Aborting! Setting local mode... Reading imei... IMEI/ESN: ??????????????? Reseting warranty data... Reseting LifeTimer... Lifetime data not found!!! Done! Powering the phone... Unlocking... IMEI: ??????????????? ASIC: b SW version: 4.11 Selected flash file: C:\Documents and Settings\Administrator\Desktop\Patches\RM-305_V_4.11_359563015568458_patch.mcusw Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 02 MCU ID: 0x2292 Algo is ready... P-key nokia module version 01.02 Erasing area: 01200000 - 0121FFFF... Erasing area: 011E0000 - 011FFFFF... Failed! Aborting! Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 8490DD5FEDA2A2461682F3240E MSID decoded: 3E4EBAE9005F4B85A9000000 FAID: 8BBA364576790F369075B350 Operation took 0 minutes 16 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 30 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 13 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.11ej Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 845CA632296C80AA892FC5C96C MSID decoded: 3E4EBAE9005F4B85AA000000 FAID: 0A7921C78107EA9E5FA2E198 Operation took 0 minutes 16 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 10 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 6 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai4.11ej Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 8490DD5FEDA2A2461682F3240E MSID decoded: 3E4EBAE9005F4B85A9000000 FAID: 8BBA364576790F369075B350 Operation took 0 minutes 15 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 2 minutes 30 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-105, Software version: 4.11 IMEI: ??????????????? Product Code: Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 8 seconds... Done! Done! Powering the phone... Unlocking... IMEI: ??????????????? ASIC: b SW version: 4.11 Selected flash file: C:\Documents and Settings\Administrator\Desktop\Patches\RH-105_V_4.11_358088001236580_patch.mcusw Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 02 MCU ID: 0x2292 Algo is ready... P-key nokia module version 01.02 Erasing area: 011E0000 - 011FFFFF... Erasing area: 011E0000 - 011FFFFF... Unlocking... Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 1 Setting local mode... Reading imei... IMEI/ESN: 350016000211112 Reseting warranty data... Reseting LifeTimer... Lifetime data not found!!! Done! I did it.. thanks to the tread starter... |
1200, 1208 And 1650 led solutions | erick_ponsel88 | Nokia Hardware & Hardware Repair | 2 | 10-14-2011 18:02 |
1200 1208 And 1650 Imei Patch FILES | Dooha_Bd | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 02-14-2010 14:36 |
1200 1208 and 1650 ???????????? solution [.imei patch] | an.sanji | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 01-24-2010 12:48 |
