3510i dead nokia 3510i no network after flash with rh9__05.350 + rh9__05.35c phone is dead ani solutions pleas Thanks for all |
The phone was flashed successfully? Try make it erase flash and flash again. Try reflash it with other SW ver. |
yes the phone was flashed successfully after flash dead now it doesn't accept any flash Msg error = Unknown flash manufactures 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x00FFFFFF,478DBB37, Algorithm: Unknown 2nd Boot Error: Error Data1: 00000000: 9F 01 02 01 47 8D BB 37 00 00 B8 DC 00 00 02 1B ....G..7........ 00000010: E5 4F F8 00 00 00 00 00 00 0B 05 53 D9 78 2A B2 .O.........S.x*. 00000020: EE C9 BC 51 BE 3E 71 2B A9 C3 00 00 00 00 00 00 ...Q.>q+........ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: 01 47 8D BB 37 00 00 B8 DC 00 00 02 1B E5 4F F8 .G..7.........O. 00000010: 00 00 00 00 00 00 0B 05 53 D9 78 2A B2 EE C9 BC ........S.x*.... 00000020: 51 BE 3E 71 2B A9 C3 C3 72 00 00 00 00 00 00 00 Q.>q+...r....... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Before taking screenshot, expand this window ! Process Failed, Repowering Mobile I have tried - WR PM respond: Init Local Mode Failed Write PM Failed ave any solutions?? :confused: :confused: :confused: Best Regard my ICQ is 273321418 |
@ Decibell exuse for my bad english but i hope you understand. |
Probable you have wrong TIA/FIA files. When the some phone FW installs it removes some TIA/FIA files in the work directory of the UFS_DCTx. 1. Fully reinstall you UFS DCTx soft. 2. Make backup from [C:\Program files\Nokia\Phoenix\Flash\*.*]. 3. Install phone FW. 4. Try to flash. 5. If not works restore TIA/FIA from backup and flash again. 6. If all it not solves try to heat Flash IC. I thing so... |
i have also incounter that kind of problem. msg error: unknown flash manufacturer..what is this mean? pls anyone responce. tnx |
@ Decibell Thanks Decibell I have done everything as you have said, unfortunately without any risult the error message is always the same..... Thanks however. @Pazeth Thanks you can tell me other flasher? |
