Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
08-21-2006, 06:47 | #1 (permalink) |
Freak Poster Join Date: Dec 2004
Member: 96236 Status: Offline Thanks Meter: 7 | 6230 write imei failed i have a 6230 no network, uem heats up and has defect. i try to change uem using from a working 3220 with a ready rpl backup but ufs does not write rpl. even tried jaf but still not write and imei is ?????????????. i also tried using blank uem using griffin server logs but also it can't write. Prior to writing imei, 6230 was fully flashed successfully with working 6230 pm also written. here are results: jaf imei tool: Power on the phone... Reading imei... ??????????????? Opening RPL file... Inspecting... IMEI: 35762300xxxxxxx DATA2 key is missing....Will be skiped! Booting phone... MCU ID: 0x1052 Sending algo... Algo is ready... Writting UEM... Error writting uem... ufsx: IMEI: ??????-??-??????-?, ASIC: 6 RPL File Info: IMEI: 35762300xxxxxxx CHCK: -2360 Warning: No DATA2 Record IMEI: ? PROD: ? 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x027FFFFF,00EC0039,Sam KEE00E00CM Algorithm: te_amd_b.fia, Ver: 4.52.0 UEM Writing Failed: Wr_UEM Wuem 15 UEM Write Failed br, beega Last edited by beega; 08-21-2006 at 07:15. |
08-24-2006, 20:34 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: [winscard.SCardTransmit]
Member: 8023 Status: Offline Thanks Meter: 13 | LOL!!! you are quite good if you managed to get off UEM without damage but: - you CANNOT use 3220 UEM to 6230 - you must use EMPTY UEM - you CANNOT write "RPL backup"! you MUST pay for RPL, and you need to use ASIC6 RPL... no more problems |
08-26-2006, 12:12 | #4 (permalink) |
Member: 96236 Status: Offline Thanks Meter: 7 | oops i forgot the which asic type it is since both uses uem2.0. however i have solved it. thanks anyway @edcentec that is such a nice phone. i just got too excited since i removed uem perfectly and used another uem w/ a backup hehe |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
write imei failed inside firmwere | deepaksawdia | Infinity-Box | 10 | 01-29-2010 20:21 |
Operation failed when trying to write imei on D720 | Burnt Cobba | NSPRO | 0 | 12-20-2006 00:34 |
D500 solution for write imei failed | imo | TST Dongle | 0 | 12-16-2005 15:18 |
2100 write imei failed | hyper_wamir | Nokia Hardware & Hardware Repair | 5 | 11-18-2003 03:19 |
