Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
10-16-2003, 10:55 | #1 (permalink) |
Freak Poster Join Date: Aug 2001 Location: GSMLAND
Member: 5764 Status: Offline Thanks Meter: 2 | is it possible to replace flash chip on DCT? The problem is that nobody have blank UEM. I tried chinese UEM's, and they are all not working, or not blank. If I have one GOOD UEM from one phone, and GOOD FLASH and UPP from another phone, is that going to work? |
10-16-2003, 16:21 | #2 (permalink) |
Registered User Join Date: Oct 2003 Location: Vietnam Age: 47
Member: 40808 Status: Offline Thanks Meter: 10 | Hi, it possible to change flash and power ic on dct4. If u change power ic, after flashing u must rebuilt imei and power ic must be brand new! China flash and power ic is no problem, if u haven't got a new one u can reflow by a pair of flash and power ic from another phone too! It's test by me! B.G. |
10-16-2003, 23:12 | #4 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | 1. If you change the flash IC only, you can only REWRITE the same IMEI to the phone. If you change the UEM with a BLANK NEW one, then you can change the IMEI of the phone. 2. Griffin can be used to write the IMEI to the phone as well as other IMEI Rebuilder Boxes out there that uses original Nokia RPL files. I am told that there is no quick way to test whether the UEM is old or new, unless by putting it on the PCB. If the phone restarts in less than 40 seconds, then it is old... if it doesn't then it is new. But sometimes even new UEMs have other internal problems such as loss of voice quality on calls and other functionalities. Best Regards, X-Shadow |
10-17-2003, 03:02 | #5 (permalink) |
Member: 5764 Status: Offline Thanks Meter: 2 | thanks for answers. Now I have only one question - where to get original nokia rpl files ? there are no rpl files on griffinteam and griffinbox as well as in forunm sites. |
10-17-2003, 03:25 | #6 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Earth Age: 49
Member: 10387 Status: Offline Thanks Meter: 3 | [QUOTE]Originally posted by X-Shadow [B]1. If you change the flash IC only, you can only REWRITE the same IMEI to the phone. but how to rewrite same imei when the flsah ic is dead (how to create flash data to much uem except fps8) |
10-17-2003, 05:46 | #7 (permalink) |
Member: 5764 Status: Offline Thanks Meter: 2 | as I understood, it is possible to write IMEI that stored in UEM to flash from another phone. isn't it? I will replace DEAD flash with another flash, from ANOTHER phone. |
10-17-2003, 06:17 | #8 (permalink) |
Member: 871 Status: Offline Thanks Meter: 602 | @cmk To RE-WRITE the same IMEI to the same phone but with new blank flash ic, you need original equipments for now... Because you will need to apply for an "RPL" which is specifically made for your phone. The process is easy, but requires a certain amount of resources and contacts (for now). Some 3rd party IMEI Rebuilders can also do this, just as long as it can use original RPL files then it should be possible. The problem however is making the "ASK" file (log) and sending it to NoKEyA for a responce "RPL" file. @sat I dont quite undrestand what you are asking. But I hope my reply for cmk will be clear enough. I dont want to go into too much detail, unless of course the topic is still not clear for all. Best Regards, X-Shadow |
10-17-2003, 09:20 | #9 (permalink) |
Member: 10387 Status: Offline Thanks Meter: 3 | [QUOTE]Originally posted by X-Shadow [B]@cmk To RE-WRITE the same IMEI to the same phone but with new blank flash ic, you need original equipments for now... Because you will need to apply for an "RPL" which is specifically made for your phone. The process is easy, but requires a certain amount of resources and contacts (for now). Some 3rd party IMEI Rebuilders can also do this, just as long as it can use original RPL files then it should be possible. The problem however is making the "ASK" file (log) and sending it to NoKEyA for a responce "RPL" file. as i know it must big money if standalone and i think in short time griffin can provide read log function to correct flash chksum hope the log $ can acceptable (cheap than uem) |
10-17-2003, 12:42 | #12 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Netherlands
Member: 2100 Status: Offline Thanks Meter: 40 | @ X-Shadow: I replaced some flash IC's in DCT4, I dont think MUST change imei, only reset SP-locks (and splocks is no problem with current soft) only imei in flash will be 0000000000000's in uem still original (*#waranty* will give 000000000's ) I think biggest problem for most members is to calibrate unit CORRECTLY again after changing UEM (rf and EM part) |
10-17-2003, 18:41 | #13 (permalink) | |
Member: 10387 Status: Offline Thanks Meter: 3 | Quote:
correct me if i wrong | |
10-17-2003, 22:38 | #14 (permalink) | |
Member: 2100 Status: Offline Thanks Meter: 40 | Quote:
-reflash phone -REBUILD SPLOCKS with neelix, griffin or whatever (so just unlock) -EM calibrate phoenix + jvb-1 -RF Calibrate+ phoenix + 8922 Thats it phone working no need to rebuild Imei or whatever (phone imei in *#war0anty# = 0000000's) But imei sending to network (*#06# is the one in UEM) When I CHANGED the UEM all I do is: -Choose ANY RPL file I have in my "database" or make a ASK file -Connect 12v to JVB and connect via fps8 -use the "wizard" to complete it. After this, phone get IMEI and PRODUCTCODE from RPL file I choose. When connecting to wavetec NET tester I see IMEI I JUST make in NEW UEM. When looking via *#war0anty# I see "imei in flash(old one)" | |
10-18-2003, 08:41 | #15 (permalink) |
Member: 5764 Status: Offline Thanks Meter: 2 | -reflash phone OK -REBUILD SPLOCKS with neelix, griffin or whatever (so just unlock) OK -EM calibrate phoenix + jvb-1 WHAT TO USE TO CALIBRATE IT? -RF Calibrate+ phoenix + 8922 WHAT TO USE TO CALIBRATE IT? |
Is it possible to read flash from one phone to flash to other same model | msa | ARM9 BASED M62 / M62+ | 3 | 04-15-2012 09:22 |
is it possible to download ring tones on a800 with data cable | acronus | Samsung Media, Games, Ringtones | 5 | 02-07-2006 06:09 |
Is it possible to repair error 4016 on T230? | roniri | DIV | 7 | 12-05-2005 17:31 |
Is it possible to change IM*I on SE Z200, and how? | Ottone | SonyEricsson (USB-Smart) | 2 | 11-10-2005 11:13 |
Is it possible to change the imei on a S55?? | speede | E-Gold Based Phones | 0 | 09-14-2003 22:18 |
