Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
05-16-2006, 10:18 | #256 (permalink) |
Junior Member Join Date: Jan 2006
Member: 222827 Status: Offline Thanks Meter: 0 | I flash FTD_rm74_y3.430 to my 6030 phone, my tool: JAF BOX by odeon,soft v1.95,P-key, 6030 cable. this is the message of JAF flashing: Detected PKEY: 900008B6 Card life counter: 99.96% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.A4 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Detected P-KEY: 900008B6 P-key nokia module version 01.00 Changing mode...Done! Setting local mode... Phone current mode 02 Reading... Phone Type: RM-74 FILES SET FOR FLASHING: MCU Flash file: D:\DownLoads\Field_test\6030_FTD_rm74__y3.430 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE MCU: D:\DownLoads\Field_test\6030_FTD_rm74__y3.430 Booting phone... MCU ID: 0x2031 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.34.00 -> Revision: 0007 Boot size is 0x0948 Boot is ready... FLASH ID0: 00012C7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2C0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.34.00 -> Revision: 0007 Loader size is 0x6E98; Loader chk: f3 Loader is ready... P-key nokia module version 01.00 MSID: 84AB7128B7D1520C35FE0954E6 MSID decoded: 9F7EBAEF00C413C1A8000018 FAID: 2806808FEC5D08EF313142D9 Operation took 0 minutes 22 seconds... Erasing... Found 3 interval(s) to erase Erasing area: 01000000 - 0101FFFF... Erasing area: 01020000 - 017BFFFF... Error erasing area: 01040000 - 0105FFFF FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Setting local mode... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Setting local mode... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! Powering the phone... Failed! Aborting! MCU ID: 0xCCCC This phone is not supported for memory read... Boot load error... question: I can't power my 6030 with battary, don't connect 6030 with JAF BOX, how can i solve these problem? |
05-16-2006, 12:03 | #257 (permalink) |
Freak Poster Join Date: Oct 2003 Age: 49
Member: 41760 Status: Offline Thanks Meter: 16 | I haven't worked with JAF, but from the logs it seems like you had a problem with bad contact or something; therefore, a problem erasing flash (Erasing area: 01020000 - 017BFFFF... Error erasing area: 01040000 - 0105FFFF). And since some flash has been erased, the phone won't power up. Try flashing it again. Make sure the contact between the board and connector is firm (both the battery contacts and the flashing contacts). Check if all the contacts are clean and if battery contacts are not bent. You may have to take just the board by itself and hold the flashing connector and the board by hand for a better contact. This is more difficult, but better contact. And another question: in the beginning of your log: FILES SET FOR FLASHING: MCU Flash file: D:\DownLoads\Field_test\6030_FTD_rm74__y3.430 PPM Flash file: NONE CNT Flash file: NONE. Are you sure about what you're doing? Flashing MCU alone is not right; you have to flash a matching PPM and CNT file for your phone to work properly. |
05-19-2006, 15:13 | #263 (permalink) | |
Member: 41760 Status: Offline Thanks Meter: 16 | jew2jew You must feel lucky that I'm not a moderator here! If I were, you'd be banned now. Five posts in a row, only two of them have slight relevance to the topic (the two requests, for 6233 and 6280). What on Earth are we supposed to do with the pictures of Ericsson TEMS phones? And with Griffin schematics? And what on Earth is this supposed to mean: Quote:
05-24-2006, 22:20 | #268 (permalink) | |
Major Poster Join Date: May 2006 Location: Nearby my COMPUTER Age: 41
Member: 274923 Status: Offline Thanks Meter: 1 | Ppm Quote:
Regards GsmDemon | |
05-25-2006, 12:10 | #270 (permalink) | |
Junior Member Join Date: Mar 2006 Location: Russia.Ekaterinburg Age: 56
Member: 243224 Status: Offline Thanks Meter: 0 | Quote:
Best regards. | |
