FTD/NetMonitor here is some patched MCU's with field test display enabled please try and post results 7250i - v5.41 - with ST_SW_TYPE_VALIDITY_TEST repair thanks to Alex 6610i - v4.20 - with ST_SW_TYPE_VALIDITY_TEST repair thanks to Alex 6650 - v5.40 7600 - v4.03 6310 - v5.10 6310i - v7.00 6100 - v6.20 6200 - v4.22 5140/5140b - v3.17 3100/3120 - v6.11 7200 - v4.30 5140i - v3.70 2300 - v6.64 6230i - v3.50 6030 - v3.43 7210 - v5.63 6610 - v5.65 8310 - v6.20 6510 - v4.21 3510i - v5.35 3200 - v5.34 Document about FTD and commands use any ppm you like for the same mcu version B.R Neo |
For me the 6230i flash file are not working!! But I have also a problem to enable with J.A.F. the FTD Menu . Maybe it`s a general TIKU problem ??? |
But not all TIKU have problems. 6650 / 7600 / 6230 work fine. |
Tested with J.A.F. 7250i -> OK! (only work with "FTD ON" enable) 3200 -> OK! 6610i -> OK! BR :) |
In 7250i w/o FTD ON doesn't work :confused: |
What about field test for nokia 7260 v4.91 ? Just flash 6310i works 100% :) |
thanks sir... now..... wait for partial flash files :D |
FTD On Partial Flash Files... 3100/20 3200 3510i 6610i w/CS patch 6100 Thanks NEO for the Flash Files FTD Patched. :D |
ei monxxx, tested and flash so eaisly, working! good job, thanks also to NEO for the patched with netmonitor mcu br |
Neo, excellent, netmon was always of great interest to me, do you have any avilable for the 6230? |
6230i FTD now available with JAF |
Yes it`s really working with J.A.F. now, I have testet it!! |
