@GIUGIARO 1100 v5.62 i think its working... please make sure that your 1100 flashed w /v5.62 before flashing this partial flash file... don't for get to UI Settings |
did anybody sniffed the claudia info that jaf sends to phone when flashing 6230i ftd? |
6230i, net monitor not working :( |
@german gsm team what soft do we use to sniff? snoopypro? thanks |
if usb connection to box is not crypted, it should be possible |
Hi, 1. Start Snoopy. Click Toggle USB devices. (0.jpg) 2. Scrow down to JAF FLASHER INTERFACE (1.jpg) 3. Right click Install (2.jpg) 4. Then right click Install Service (3.jpg) 5. Close the USB devices window 6. Plug jaf and you should see this (4.jpg) 7. Start jaf and do the flashing. At the end press the square stop button in the snoopy log window. 8. Save the file. 9. Open the created *.usblog file with winhex and seach for binary string 'XXXXXXXXXXXXXXXX', where XX is first 8 bytes block of Claudia. You can find those in in the MCU header of the flash file you just flashed ( 0xD3, 0x40, XXXXXXX.....). Enjoy PS: Don't forget to uninstall the service and the filter driver when you are done, otherwise you can get some cool blue screens. FTDI driver is still quite buggy. |
http://switch.dl.sourceforge.net/sou...pyPro-0.22.zip ist the needed software do the tests with jaf 187 beta 10 or 187 final a logged flash of 6170, 7270, 8800 would be great, too. I'm not sure, but as far as I know claudia info begins with 0xD3 0x40 . the next bytes for rm-72 mcusw 3.50 are 7A 7F D0 2F CD 22 2C 3C 6E 45, but we need the next 64 bytes, that were logged. |
Typing error. Edited the posting now. Thanks |
@NOKMASTERgsm Does the partial flash work with UFS3, thanx for reply. |
The first step is to Unpack the drivers - F2 -> File -> Unpack Drivers BR Daniel |
@indear pls tell me how to "ON FTD"? i've been trying to patch FTD with 7250i mcu but no success... |
can we use with UFS-3 Please help |
error with Karvows error with Karvows (192) debugger detected please disable it and restart the application no more FTDI devices left (all in use,dummy searials, or not compatible with this software) try to reconnect USB cabe if devices not in use what to do |
