hard way to unlock 1661 just change upp with 1208 one, flash it with mxkey and unlock it, enjoy |
I tested and works 100000000000000000% Tanks !!!!:D:D:D |
hehehehe flash:D:D:cool: |
1st need upp then flash is better buy a new mobile |
Please where can i locate upp in phone? Can some body send a picture solution of the upp? thankx |
dear brother not work hi hi hi hi hi hi |
Please post more details like: -What flash files did you usedd for that?...from 1208 or 1661? -Did you write PM eather? |
risky move.....unit might be dead...hheheheheeheh |
Change with 2nd 1661 board.... the best way..... :D:D:D |
how much a customer gives charges to unlock 1661???? think abut it... it is risky but costly too and time consuming thing... its better to do some other work instead of changing upp and then flash .... but if u r totally freeee u can do this to pass ur time .... :D |
plz share log............. |
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12656(19-03-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C6465B:DA3BDA66 ASIC type: 11 UEM Imei: 35xxxxxxxxxxxxx ersion Info: MCU SW version: V 03.70 14-04-09 RH-122 (c) Nokia HW version: 1001 UEM version: 1328 UPP version: 8850 RFIC version: 0700 DSP version: ICPR81_09w10_UPP LCD version: TPO:BOHAIv80 HX5081 PPM version: V 03.70 14-04-09 RH-122 (c) Nokia EE ADSP SW version: p V 03.70\n14-04-09\nRH-122\n(c) NMP\nee Product Info: Production serial number: DWE963871 Product code: 0580314 Module code: 0204078 Basic production code: 0568809 Serial Numbers: IMEI plain: 355221030912938 IMEI spare to net: 3A 55 22 01 03 19 92 03 IMEI SV to net: 33 55 22 01 03 19 92 23 F5 Other Info: CS type : GSM/DCS1800 BSI: 4.9 KOhm Imei net: 355xxxxxxxxxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
