Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
10-17-2002, 10:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | how to make backup on the 8310? 2. How to make full backup on DCT-4 phones? 3. How to flash the phone? As far as i know from the flasher prog, it only flash the PPM, not the MCU. 4. HELP..... Thanks in advance. |
10-17-2002, 11:27 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 53
Member: 4611 Status: Offline Thanks Meter: 68 | As far as I know, you cannot backup the flash from a DCT4 yet (correct me if I am wrong). You can however backup your phonebook, etc. Lord only knows what flasher you are using if it will not let you flash the MCU. If you are unlucky, and cannot flash mcu with it, then stick it in the bin and buy another from this fourm. They sell for around 150 pounds, but look around, you will find cheaper |
10-18-2002, 17:54 | #5 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | then how to flash the phone? when i open the ppm file 0506.....s, and click flash, the phone shows up local mode, sometimes test mode and then the flasher stops. why? |
10-19-2002, 18:03 | #6 (permalink) |
Product Supporter Join Date: Jan 2002 Location: Philippines
Member: 8303 Status: Offline Thanks Meter: 127 | at the moment, we cant read the contents of DCT4 phones. we have to patch the flash loader to be able to read DCT4. unluckily, no one has the solution for patchng the flash loders so we have to wait for the solution. |
10-20-2002, 03:23 | #7 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | 1.Open a flash file by clicking on ppm file ex. nhm75505.54d 2. be shure that PPM box is NOT CHECKED 3. flash the phone P.S. after MCU flashing your phone will get into LOCAL MODE take battery out and back in and click on OK,after that power on phone shortly again to flash PPM.....your phone after flashing AGAIN in LOCAL mode....... Take battery (connector) out and all OK......... |
10-21-2002, 05:01 | #8 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | @Abe Thanks for your kind help. Do i need Faid calculation after flashing? (Like in the DCT3) And how do i make a FULL BACKUP? which address start and which address end? Is it like DCT3 way to do it? I'm new on this DCT4.. TIA. |
10-21-2002, 05:23 | #9 (permalink) |
Super Moderator Join Date: Aug 2000 Location: Malaysia
Member: 1922 Status: Offline Sonork: 100.64645 Thanks Meter: 692 | no..you no need to calculate anything, if you use the cheap flasher dongle you need to press the power on once only after that take out and fix back the cable again |
10-21-2002, 18:09 | #10 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | i try to flash, but each time when i upload the file and click the Flash button, the screen from the phone will show local mode and then the windows in the computer will show TX pin remains unchanged....Why? |
10-23-2002, 15:46 | #11 (permalink) |
Insane Poster Join Date: Oct 2002 Location: Europe Age: 45
Member: 16977 Status: Offline Thanks Meter: 1 | If you use now cheap flasher, you must reconnect the phone to cable after the flasher upload the mcu. If the flasher write Please OFF the phone, you must get off the phone from cable, and take again to cable. (always check: the lcd must be empty, (not local mode)), and press Ok! And the flasher will upload now the ppm... Use AFD or Neelix2... Thats are the BEST! |
How to make Backup | shoaibrao | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-04-2010 22:23 |
HOW to make backup certificate ????? | Rezn | Universalbox | 0 | 12-02-2008 17:24 |
how to make backup by ub | talatmehmood | Universalbox | 6 | 01-24-2008 12:03 |
How to make backup security field | owiec77 | MT-BOX | 3 | 02-26-2007 14:44 |
