New silver NK 2610 AT&T problem Hi everyone. Got a new NK 2610 USA AT&T version. silver. stupid ATT use glue to cover the f-bus connector. I also tried with easy cable but no luck. Anyone can share how to get around the block of the easy cable? Thank you! |
I removed the glue but it will not read the phone. The phone reads "Local Mode" or "Test Mode" but I get the following error on 20pcs I have tried. JAF version 1.98.59 Detected PKEY: XXXXXXXX Card life counter: 94.05% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 6.86.11.0 Setting local mode... Failed! Aborting! Setting local mode... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! Changing mode... Failed!!! |
compare 2610 board with 1600. or2310 or 1110 you will see something missing next f-bus connection , then replace with those of fone mentioned |
no need to replace, just short contacts with fine wire 4 times then patch unlock via jaf |
It's 4 resistors that AT&T removed. Recalled me Tracfone did to 1100 years ago :D How to get rid of glue over the connector? Any way I can use easy cable without short cut the resistor? Thank you again |
make short at resistor array location = no problem, peel off glue, very easy with knife and little hot air. easy cable dont work for me. i like unlock of this phone charge a little more to customer, thank you att |
Can you explain the process in detail? I don't understand..... any help is appreciated. |
there left 8 small dot in two rows. short cut them and down and you are good. Mrfixit, Thank you again mate. |
can someone plz post pics and explain how to short (what method)? will be greatly appreciated... |
I don't mean to sound stupid..... but what do you mean by "make short at resistor array location" Do you mean cut them with a knife or use a fine wire and connect the dots together? If you do mean cnnect the dots together, would an IC chip work? and if so, do they make them that small? |
Thanks for the pic. Do I cut with a knife on those 4 lines or do I use a wire where the 4 lines are? |
Anybody know where I can purchase the IC chip that belongs here? Quote:
do u fix phones??? Quote:
be good Br.T:D |
2610b from AT&T with glue on board 1 Attachment(s) the 2610b on this question i have one and need to put 2 resistors on board in picture attached. need array resistors but i think to jumpers its ok. |
