new solution to repair nokia (1100) imei ???????????? ok 100% 1 Attachment(s) new solution to repair nokia (1100) imei ???????????? ok 100% new solution tfirst flash mobile 6.64 ver. press patch button to ufs chooise file RH-18_1100_6.64_imei repair.jud enter org imei and update file to phone mobile now contact service reflash phone same ver(6.64) use uisettings all done |
and ur phone is off in 32sec... so this is not a solution its only patch imei.. |
I need 2300 imei patch any body help me |
yes thanks but but it is my solution ........ |
DCT4 DIRECT BOX,HWK,J.A.F,MT BOX,GRIFFIN,ANY box.. cannot work with phones that: - Have bad UEM data (30 sec off problem) - Don't have any UEM data at all (?????????????? IMEI/ESN) - Have SOftware/Hardware problems Please always check if phone is in full working condition before starting the IMEI/ESN change procedure. If you want to bring the phone back to it's original state, then you only need to flash the phone with origitnal MCU software. After MUC software update the patch will be erased and the phone will operate as before. LAW GSM |
solution don't work fake fake fake :) because hardware problem |
will try and post result...... thank u mahmood shad pakistan |
Solution will not work if UEM is damaged BR, xyz |
ok All Guys Dont fight Chek the solution and post your Result....WBR..... |
After Flash Again Imei ???????????? |
yes work fine but but no signal ???????? |
Its really FAKE !!! |
dear friend i have recived nokia 2300 . water dames i flash it now the phone open but imei ????????????????????????????4 how to possibal solved it plz help me any body |
after flash ?????????????????? hi, but not working for me, Quote:
no proper solution set comes off after 32 sec not good solution y2ksalman |
