Nokia 1100 No Network After Flash Hi Friends! I flashed Nokia 1100 with Twister coz after some time its displays car sign on screen and no ring tione for calls just callers number that problem was fixed now means no such sign now But No network as well i flashed it with v.6.11 just MCU and PPM any suggestion.. WR.. |
erase flash file then flash mcu and ppm and then upload pm file do simlock and full factory setting thats all |
please write in Nokia 1100 pm flash file to the phone, and run full iu setting including unlocking, format user area,i hope this will solve no network promblem, try and reply. |
I mean you should write full Pm to phone and run unlock after flash with correct flash files( mcu & ppm ) must match. |
write pm..................... |
Here is the result of 1100 Quote:
Hi Mate! i flashed nokia 1100 with twister as you said and here is the result. I mean LOG 1st Boot Ok, DCT4, UPP: 1201 Fl0: 0x01000000-0x011FFFFF,002088DE,St M58MR016C Algorithm: u_st_i.fia Algorithm Ok, MSID: 840B337B3EF083DAE454581629 Decoded MSID: 3E4EBAE9-008525DF-A9000000 Encoded FAID: D60412A5-BADD5FED-DE24A896 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x011EFFFF Erased, Time: 00:27 Area3: 0x011F0000-0x011FBFFF Erased, Time: 00:01 Area4: 0x013F0000-0x013FBFFF Out of Chip Bounds Area5: 0x017F0000-0x017FBFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:08 Area1: 0x01170000-0x0117FFFF Erased, Time: 00:00 Area2: 0x01180000-0x011EFFFF Erased, Time: 00:06 PPM Flashing Completed, Time: 00:02 Flashing Completed, Rebooting Mobile Any Solution of Out of Chip Bond i faced it while flashing 3120, 3100 and 1100 several times Any Suggestions |
"Out of Chip Outbounds" it is no problem. this information show program can not erase data area in Flash Chip because all data has been remove in Area-3. So program not found data again in Area-4 and Area-5. I am sure this information "Out of Chipbounds" is OK, no problem. If your problem only on Signal. I think is very simple problem. All member has been help you with say Write Pm, Write Pm and Write PM. |
If u have saved your original pm maybe u will make your phone to have signal .... search on the forum ..... http://forum.gsmhosting.com/vbb/showthread.php?t=134661 |
Read this. It will hwlp you http://forum.gsmhosting.com/vbb/show...63#post1380763 |
the answer to your problem are some spongees sticked to the procesor`s :D to keep them stuck to the bord |
did you flashed it rh38 or rh36? |
Writre PM helped me, repaired 2 units today. |
try to write pm...... |
