Nokia 6020 send key and end key not work, Hi mates,I have nokia 6020 the problem is send key,end key and side volume swich are not work,I replaced keypad Ic but still same problem,I need solution please help me, Thanx in advance. |
1 .write good PM , if problem not solved ,backup all your data (like as Phone book , pm file , ask file until your RPL phone) and then try to full flashing. and if that step evenly not solving your problems,try step 2. 2 .clean your PCB , and check it again,..hope work. 3 .still not solved?..check key ways...search / googling. 4 . if still with the prob,i think you must rehot you ic,1st the UPP. good luck. correct if wrong. br |
hi baby the send key and volumekey and end key tocreate jumpering i am sure it is working may it is not working plese try it change ic |
hi baby the send key and volumekey and end key tocreate jumpering i am sure it is working may it is not working plese try it change ic and hot cpu |
plzz change keypaid ic near cpu and your problem is solve |
change C P U.......bro..... |
