Nokia c1-01 usb flashing drvier needed for flashing !!! i want to flash nokia c1-01 with atf or ufs but it shows unknown device. Kindly give me drivers for that thanks in advance... |
reinstall nokia pc suit or ovi |
i did that but still no result.... |
just u need to install nokia pc suite or ovi suite. |
use DC-Uninstall then try post result |
Did that but no solution yet... Give me drivers only..... IF I COULD GET THE DRIVERS I COULD SET IT MANUALLY.. |
Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__06.15.mcusw PPM : rm607__06.15.ppm_e CNT : rm607__06.15.image_e_0595542 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- |
Nokia_Connectivity_Cable_Driver_7.1.45.0.msi |
chek this bro...... http://i384.photobucket.com/albums/o...ra/c1-01-1.jpg insert usb on your phone and tick flash and press power key.. |
Thank you all i could do flashing now but after flashing when i insert battery it shows local mode but after flashing it start completely well.. How to solve this local mode issue ? I flashed with 3.75 version which is the latest on atf so what to do now ? |
Flashed with latest version 6.15 all done boss !! |
unexpected exception: search for usb device time-out:[oooo103] no more data when i check for flash c1-01 with hwk solution |
unexpected exception: search for usb device time-out:[oooo103] no more data when i check for flash c1-01 with hwk please give me solution |
