Nokia Digital Core Technology 4 ( DCT-4 ) DCT-4 Phones: 1100 , 1100 , 1101 , 1108 , 1110 , 1110 , 1110i , 1112 , 1112 , 1112i , 12i GSM Modul, 1600 , 1600 , 2112 , 2125i , 2126i , 2128i , 2255 , 2300 , 2300 , 2355 , 2600 , 2650 , 2651 , 2652 , 2760 Americas, 2760 Europe/Asia, 30 Terminal, 3100 , 3105 , 3108 , 3120 , 3120 , 3125 , 3128 , 3129 , 3152 , 3155 , 3155i , 3200 , 3205 , 3205i , 3220 , 3220 , 3300 , 3300 , 3320 , 3321 , 3360 , 3361 , 3510 , 3510i , 3520 , 3530 , 3560 , 3570 , 3585 , 3586 , 3586i , 3587 , 3587i , 3588i , 3589i , 3590 , 3595 , 3595i , 5070 , 5070 , 5100 , 5140 , 5140 , 5140i , 6010 , 6012 , 6015 , 6015i , 6016i , 6019i , 6020 , 6020 , 6021 , 6030 , 6030 , 6050 , 6060 , 6060 , 6061 , 6070 , 6070 , 6080 , 6080 , 610 Car Kit, 6100 , 6101 , 6101 , 6101 , 6102 , 6102 , 6102 , 6102 , 6103 , 6103 , 6108 , 6111 , 6112 , 6152 , 6155 , 6155i , 616 Car Kit, 6170 (TIKU) , 6170 (TIKU) , 6200 , 6220 , 6225 , 6225i , 6230 (TIKU) , 6230 (TIKU) , 6230i (TIKU) , 6235 (TIKU) , 6235i (TIKU) , 6236i , 6255 (TIKU) , 6255i (TIKU) , 6256 , 6256i , 6310 , 6310i , 6340 , 6340i , 6360 , 6370 , 6385 , 6500 , 6510 , 6560 , 6585 , 6590 , 6590i , 6610 , 6610i , 6650 , 6651 , 6800 , 6800 , 6810 , 6820 , 6820 , 6820i , 6822 , 6822 , 7200 , 7210 , 7250 , 7250i , 7260 , 7270 (TIKU), 7270 (TIKU) , 7280 (TIKU) , 7280 (TIKU) , 7360 , 7380 , 7600 (TIKU) , 7620 , 810 Car Kit, 8310 , 8390 , 8587 , 8800 (TIKU) , 8800 Sirocco Edition (TIKU) , 8801 (TIKU) , 8910 , 8910i , D211 , Nokia Remote Camera DCT-4+ (Plus) : 1200 , 1208 , 1208b , 1209 , 1650 , 1650b , 1680c-2b Classic, 2310 , 2600c , 2610 , 2610b , 2626 , 2630 Americas, 2630 Europe/Asia, 2670h Fold, 5000 , 5000 , 7070 |
09-30-2007, 00:26 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Romania Age: 56
Member: 11347 Status: Offline Thanks Meter: 6 | Please help me (1110i contact service)!!! please tell me one solution that worked for Contact Problem on 1110i ! i use twister box and i write a good PM but NOT worked ! the box say this: MCU Sw: V 5.53 20-07-06 RH-93 (c) NMP PPM Sw: V 5.53 20-07-06 RH-93 (c) NMP EE Prd.Cd: 0525765 Bpr.Cd: 0520758 Pro.Sn: DHR681431 HW : 0501 PCI : UEM : 1314 UPP : 8705 RFIC : 0500 DSP : P05w06.v34 LCD : WINTK:MYKS00 IMEI : 353643-01-173258-3 SLconf: FFF-FF-FFFFFFFFFFF SLprof: 000000000001000-0 SLvar : 00003536430117325800 SLaux : 00020000 Provider: Not Found #pw+ 755 500 377 357 315 +1# #pw+ 152 244 470 054 057 +2# #pw+ 199 154 213 763 563 +3# #pw+ 729 060 246 742 271 +4# #pw+ 709 950 727 731 063 +5# #pw+ 307 456 722 516 663 +6# #pw+ 483 947 002 121 351 +7# so what i should to do? |
09-30-2007, 10:06 | #2 (permalink) | |
Freak Poster Join Date: Jun 2006
Member: 290360 Status: Offline Thanks Meter: 13 | try to flash it in JAF or UFS Quote:
try to flash it on UFS or JAF with latest firmware it will be ok......................... | |
09-30-2007, 14:26 | #4 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: United Arab Emirates Age: 33
Member: 60500 Status: Offline Thanks Meter: 2 | Quote:
BR Muneer Ahmed | |
10-01-2007, 17:40 | #5 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, 1st erase your set 2nd try to flash with lower version i think your problem will be solve post your result |
10-02-2007, 18:33 | #8 (permalink) |
Member: 11347 Status: Offline Thanks Meter: 6 | i flash it with the initial version (5.53) but phone is the same.... i want to try to full erase, flash it and write a good PM, but i don't have a good PM and the phone don't erase full...only partial! |
10-02-2007, 19:05 | #9 (permalink) |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | If u confirmed ur phone is 1110i_RH93 then take these given below steps.... -Erase Full Flash -Write Flash with the latest ver 6.40 or 6.91 -Write PM -Factory Setting -Then Unlock otherwise flash with 1110_RH70 if problem not solved so that is confirmed ur phone has not software problem, Then check phone hardware. B.R., kashi4gul |
10-02-2007, 19:30 | #10 (permalink) |
Member: 11347 Status: Offline Thanks Meter: 6 | i'm novice in this domain... you can tell me what adress is to full erase ? because i think that the adress is started with 01000000 , and ended with 013FFFFF ?? and give me one PM file that is good. thx dude |
10-02-2007, 23:26 | #11 (permalink) |
Member: 60500 Status: Offline Thanks Meter: 2 | you can get the pm file from any other ok phone...read full pm(0-225) from other phone 1110i and then upload it....and to check the erasing area of the phone you will see during flashing that which address the phone starts erasing so you will know the starting and ending address of the phone so you can do this thing manually also...and also try this phone from MT box or JAF box coz UFS sometime do creat some problems. BR Muneer Ahmed |
10-04-2007, 13:01 | #13 (permalink) |
Member: 11347 Status: Offline Thanks Meter: 6 | i try to repair with 1110 flash (mcu+ppm+cnt) but the problem is going to appear! please say me how to make sim patch !!! because i want to try this method too ! thx friends |
10-05-2007, 11:04 | #14 (permalink) |
Member: 11347 Status: Offline Thanks Meter: 6 | I FOUND THE SOLUTION : 1. Full erase phone 2. Flash with RH-70 (1110) v3.42 3. Write a good RH-70 (1110) PM !!! from 0 to 255 4. Unlock *-> now phone it's ok, but display it's not good!! (no problem) 5. Flash with RH-70 (1110) v4.04 6. Unlock *-> if your display is ok, it's done! If it's not good make make this: 1. Flash with RH-93 (1112/10i) v6.00 2. Write a good RH-93 (11112/10i) PM!! from 0 to 255 3. Unlock with FUSION & make Full UI Settings (exception Init SimLock!!!) *-> now your phone it's OK !!! ALL DONE ( tested by me) RH-70 Full PM + RH-93 Full PM + FusionUnlock => download from: http://rapidshare.com/files/60407695...1112-1110i.rar by all-gsm |
please help me 7100s contact service | Samuel maduka | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-14-2009 11:09 |
Please Help Me 7210c Contact Service Not Solved | swechacnu | Nokia Base Band 5 ( BB-5 ) | 10 | 08-26-2009 13:08 |
Please Help Me 7210c Contact Service Not Solved | swechacnu | Nokia Base Band 5 ( BB-5 ) | 0 | 08-06-2009 11:31 |
please help me ( contact service nokia 6610 ) | belal_qassam | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 06-03-2008 17:32 |
