Old 01-18-2010, 09:01   #1 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
On with 1 Second Light
1110 (rh-70) i've on the phone and light goes out after 1 second and never come back even if i press the keypad...
i has flash it with v5.53 write good pm, factory reset, but still got the problem..
there's nothing wrong with the board after i disamble it...
i've already service the phone and when it come to test, still remain the same problem...
any solution you got in mind...??
Old 01-18-2010, 09:11   #2 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
check lcd/key pad led /4volt on light coil and post result
Old 01-18-2010, 09:16   #3 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
which phone has the same coil in 1110??
there is no connection between A > B connection at coil...
Old 01-18-2010, 09:17   #4 (permalink)
Member: 1059456
Thanks Meter: 47
check display,coi,light ic problm solved.
Old 01-18-2010, 09:19   #5 (permalink)
Member: 1059456
Thanks Meter: 47
3100,3120,1600,3220 many more r same.change it
Old 01-18-2010, 09:20   #6 (permalink)
Member: 1077695
Sonork: amboy
Thanks Meter: 17
try this boss
Old 01-18-2010, 09:21   #7 (permalink)
Member: 328187
Thanks Meter: 1,687
all kind of dct4 ............
take it from any nokia phone
Old 01-18-2010, 09:34   #8 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
i has change coil... still got the problem...
can crystal light ic cause this problem??
Old 01-18-2010, 09:41   #9 (permalink)
Member: 328187
Thanks Meter: 1,687
how much voltage on coil????if less then 4 volt
then make jumper from +battery or check there is a resistor
near coil ......short to that resistor....
Old 01-18-2010, 10:01   #10 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
thanx to all....Especially Imran... already solve the problem by Changing Crytal light ic....
BB 9500 won't turn on with flashing red light naz13 BlackBerry (RIM) 4 10-19-2009 07:53
w850i when turn on -set on -with in one second turn off zonetrichur Sony Ericsson 4 10-22-2008 16:59
power on, LED of LCD is on for 2 Second !!!! JAVA Good S-Gold Based Phones 10 02-02-2007 19:47
V3 doesn't power on. Lights for 1 seconds before shutting down. James_S Smart-Clip 5 09-18-2006 00:08
Nokia 6600 no lights on lcd and no lights on key's floky Nokia Hardware & Hardware Repair 2 02-17-2005 15:01
Page generated in 0.23014 seconds with 9 queries
