Old 04-25-2006, 06:52   #1 (permalink)
yandbass's Avatar
Member: 101268
Thanks Meter: 120
1100 - 1800 Gsm Network Problem
Experts,
Many 1100 works fine with 900 GSM SIM (Airtel, BSNL, etc., in India) and signal will drop within few seconds in case of 1800 GSM (Hutch in India). This is in spite of changing PA and antenna switch. What is the best solution to overcome this problem.
Tks in advance.
Old 04-26-2006, 05:02   #2 (permalink)
yandbass's Avatar
Member: 101268
Thanks Meter: 120
1100 network problem
Kindly someone reply to the above problem.
Tks.
Old 04-26-2006, 05:06   #3 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
hutch
Tks.
In india hutch is not 1800 mhz airtel is only 1800 mhz
please change antenna switch for network low dont bridge
Old 04-26-2006, 06:01   #4 (permalink)
Member: 173215
Thanks Meter: 3
hi dear 4m which part of indiau r ??
n what is u 1100 IMEI
if it is etart 4m 010...............
u mast be chang some part...
replay me or call..9825658277
Old 04-26-2006, 06:41   #5 (permalink)
gsm_b0y's Avatar
Member: 104241
Thanks Meter: 6
Did you try to flash the phone with a new pm file?
Old 04-26-2006, 12:19   #6 (permalink)
yandbass's Avatar
Member: 101268
Thanks Meter: 120
Thank you guys. Flashing did not help me. But I feel, changing UEM is risky as it is sealed and whether there is any easy method or good flux to open and change it and then rebuild IMEI. Please reply.
Tks.
Old 04-26-2006, 15:54   #7 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
In India Hutch is 1800 Mhz.Try to search network manualy if it does't find hutch change small filter located above network IC.See in diagram which one is for 1800 band.
Old 04-27-2006, 07:04   #8 (permalink)
Member: 194540
Thanks Meter: 7
hello brothers....3310 on in only ufs.but not on in battery.plsssssss help me
Old 04-27-2006, 07:28   #9 (permalink)
Member: 194540
Thanks Meter: 7
nokia 1100, 1800 band no network vinoopt Nokia Hardware & Hardware Repair 2 04-06-2009 11:37
3100, 1100 & 6610i Network Problem. ajubaba Nokia Hardware & Hardware Repair 5 10-12-2007 10:08
Ive got a strange network problem whit 3120,signal is perfect on 1800 Mhz,but on 900 Tilka Nokia Hardware & Hardware Repair 3 10-26-2006 10:24
Ive got a strange network problem whit 3120,signal is perfect on 1800 Mhz,but on 900 Tilka Nokia Hardware & Hardware Repair 5 07-27-2006 12:42
1100 voice break over 1800 gsm network ashok_kumar459 Nokia Digital Core Technology 4 ( DCT-4 ) 4 04-01-2006 05:56
Page generated in 0.18065 seconds with 9 queries
