10-18-2005, 22:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | 1100 and 2300 charging |
10-19-2005, 10:11 | #2 (permalink) |
Crazy Poster Join Date: Jan 2003 Location: malaysia Age: 48
Member: 20545 Status: Offline Thanks Meter: 0 | something to do with it charging circuit, i changed uem & software dun work. like you say no sign, nothing. just something very funny. bat + have 3.6 voltage. i think maybe cpu misstaking that battery is full. try the temp pin. |
10-19-2005, 20:31 | #5 (permalink) |
Insane Poster Join Date: Oct 2003 Location: Europe Age: 50
Member: 42007 Status: Offline Thanks Meter: 1 | New board revisions don't have this resistor. I think it is the UEM. If you check voltage in and voltage out of the UEM it seems to be lost in there. Phone is too cheap to bother with UEM change. Too much labour to remove glued BGA and a UEM (working one) is too expensive. Curious to see sto changed UEM and no difference. Makes me think again ????????? |
10-19-2005, 22:09 | #6 (permalink) |
Freak Poster Join Date: Jul 2001 Location: macedonija skopje Age: 55
Member: 5292 Status: Offline Thanks Meter: 5 | I don't thing it is UEM problem becouse I got one 1100 who not charging (even and show ) and I change UEM with new one (blank) and put charger , phone start charging . Disconect charger and programm UEM with rpl make full factory reset and phone work at all BUT AGAIN NOT CHARGING |
10-19-2005, 22:44 | #7 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Berlin Age: 60
Member: 90804 Status: Offline Thanks Meter: 46 | 1100 and 2300 NOT charging New board revisions don't have this resistor[R100].changed UEM |
The Following User Says Thank You to GSMARMOON For This Useful Post: |
10-20-2005, 06:59 | #8 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 46
Member: 168352 Status: Offline Thanks Meter: 18 | open the phone Connect the charger socket to board,check voltage on fuse (K) both side must have charger voltage (8V) then self both side ,and one side of Zener diod. if OK and the resistor near data cable is ok,and there is no voltage on both side of R 0.22 (big resistor that is ame as 3310) then UEM is faulty |
10-20-2005, 17:26 | #9 (permalink) |
Freak Poster Join Date: Jul 2002 Location: MAD Age: 50
Member: 13545 Status: Offline Thanks Meter: 2 | 90% of NOT CHARGING problem in nokia 1100 and 2300 and 2600 phone Due to UEM, if the battery conatcts voltage out = 3.6 then try write pmm file, if not ---> UEm, if u see the battery indicator ONLY on screen the goes off, then check lines from UEM to battery contacts (change any damaged capasitor or resistor) Br ------------------ MrHazeem |
10-20-2005, 21:15 | #10 (permalink) |
Major Poster Join Date: Oct 2005
Member: 189476 Status: Offline Thanks Meter: 3 | Another Solutions Are Still Needed I THINK MORE COMPREHENSIVE SOLUTIONS STILL NEEDED TO SOLVE THIS PROBLEM I HAVE TRIED ALL MY BEST IT DOES WORK THANKX 4 UR GREAT EFFORTS MATTAKINS [email protected] |
10-25-2005, 17:42 | #14 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | Dear friends, Start with measurements 1) Check both the charger pads on PCB for shorting. 2) Check resistance of +ve pad of charger on PCB for @ 2.5 to 4 Kohms. If this resistance is OK then no need to doubt for UEM. 3) Check charging resistor continuety with battery positive. In case charging symbol appears for a while replace resistor as shown by Mr.Viks & Mr. SevgiGSM. Regards..... |
10-26-2005, 10:13 | #15 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 51
Member: 78767 Status: Offline Sonork: 100.95137 Thanks Meter: 566 | hi dear friends what rajumobile, viks, and other resp. member are saying 100% write what i am telling you is follow BSI line (midle line of batt connector) most of time i am successfully done this job |
Solution for flah Nokia 1100 and 2300 ( phones just show light in display or dead pho | leroi | UFS2 + UFS3-Tornadoflasher | 6 | 08-13-2006 20:43 |
Which box is better for IMEI PROBLEM in 1100 and 2300 | celluniversal | GSM Programming & Reverse Engineering | 16 | 01-26-2006 12:20 |
1100 and 2300 dead after flashing with ufs | toptech | UFS2 + UFS3-Tornadoflasher | 9 | 08-10-2005 12:30 |
1100 and 2300 same no network found problem | gsmsikar | UFS2 + UFS3-Tornadoflasher | 3 | 05-25-2005 19:31 |
1100 and 2300 IMEI ??????????????4 | ssatcom | Nokia Digital Core Technology 4 ( DCT-4 ) | 44 | 04-22-2005 20:40 |
