08-14-2004, 12:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | 1100 ,2300 net.... prob... help here cause every one need solution but when manual factory reset or check only oprater name on screen , no signals bars. same like 33xx series. so if any idea then pls... help here b.r. akki |
08-02-2005, 06:00 | #7 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Russia, Yaroslavl Age: 43
Member: 46415 Status: Offline Thanks Meter: 16 | hi! If you have hw prob, there are some ways to fix it: replace or resolder PA; replace or resolder switch; replace crystal osc; check antenna connector. |
08-02-2005, 17:54 | #8 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 42
Member: 152846 Status: Offline Thanks Meter: 12 | hello, i faced anothewr problem in 1100 & 2300 phones that only shows very strong network only.(also can make calls).like others replaced ant.sw,pa,filters ,flash mcu+ppm,write good pm but problem same.so what can be reason?? thanks. |
08-03-2005, 04:05 | #9 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 166746 Status: Offline Thanks Meter: 86 | anyone assit please, query with 3100 cable??? 1)any idea how the 3100 cable works on the ufs flasher tornado sereis??? its got 5 straight lines and its marked 6100... am i using the right cable... 2) my 3100 is not ringing, im trying to flash mcu + ppm, it does not want to load software, whats common problem and will s.ware fix this problem. thanks in advance, |
08-03-2005, 11:39 | #10 (permalink) |
Member: 46415 Status: Offline Thanks Meter: 16 | no, man. it's hw prob. check audioamp ic, ringer and lines. 3100 and 6100 are flashed by the same type of cable, sometimes it is needed to modify the cable. |
plz help me if any one have solution 2610 dead unlock with wrong file with jaff | bruightmobile | Nokia Hardware & Hardware Repair | 5 | 02-22-2010 21:34 |
1100-2300 colliction of solutions in one exe by chaouki GSM | bunty2008 | Nokia Hardware & Hardware Repair | 2 | 11-25-2009 18:21 |
1100 2300 flashing prob | mobilegsm30 | Universalbox | 2 | 12-19-2005 13:12 |
M35 net probs, help! | diGO | x1x to x45/x50 | 6 | 12-26-2002 22:23 |
