09-06-2006, 08:04 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Munyanja
Member: 279790 Status: Offline Sonork: icq: 648661016 Thanks Meter: 25 | 1100/2300 UI Setting Failed |
09-06-2006, 09:29 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | you must do erase first and then flash mcu and ppm and then write pm.......... if you still not able to find the phone in local mode then its hardware problem............... and in some cases you flash files are curopt so also try to reinstall the flash file................ and try to use the latest flash files version..........luck |
09-06-2006, 17:44 | #3 (permalink) |
No Life Poster Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks Meter: 97 | If the flash file version you have used is no equivalent to the version which it was in the phone before you reflash.Some time it can cause that fault,most of the time it cant show local mode so it will be impossible to ulsetting. |
ui setting failed with bb5 | coolmax | HWK | 8 | 06-17-2014 08:45 |
1100 ui setting failed | gangadhar121212 | Nokia Hardware & Hardware Repair | 7 | 09-01-2009 10:56 |
nokia 6600 software ok but ui settings failed please help | mobilecitycbk | Nokia Hardware & Hardware Repair | 4 | 08-21-2007 09:13 |
..:: 2310 flashing complete ui settings failed ::.. | HUM | Nokia Hardware & Hardware Repair | 8 | 06-16-2007 04:51 |
n-gage qd UI setting failed | gsmshare98 | Nokia Hardware & Hardware Repair | 0 | 03-22-2007 14:28 |
