1100 Hi, Please help 110 says test model I tried to flash it does not but you can read info in ufs and can do UI setting but still screen displays test mode. I change battery, screen no result please help |
Check cable,remove jack and put it again 100% from cable. |
1100 Hi, I did as you said but same problem |
its a HARDWARE Problem.. read some old threads in HARWARE section regarding local mode or test mode Br. A. Wahab PS: Thread is moved from NOKIA 1xxx |
check and replace busted parts from bsi line........ |
clean the connector or the resistens arownd it |
if dont work remove the connector and put it agin |
solution for 1100 local or test mode 1 Attachment(s) Quote:
