07-16-2004, 18:36 | #1 (permalink) |
Junior Member Join Date: Aug 2003 Location: india Age: 42
Member: 36794 Status: Offline Thanks Meter: 1 | 1100 charging problem thanks avtar |
The Following User Says Thank You to avtar For This Useful Post: |
07-16-2004, 18:58 | #2 (permalink) |
No Life Poster Join Date: Jun 2001 Age: 50
Member: 4853 Status: Offline Thanks Meter: 9 | dear sir did ur phone had a waterlock problem.then pls do mail or contact on yahoo massanger / [email protected] |
10-24-2004, 06:17 | #8 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 43
Member: 68136 Status: Offline Thanks Meter: 13 | i think beep indication due to faulty componenet or breakage of print from jack .so pls check the batt temp sensing pin, print , components(diode,resistoretc) .i hope yr problem 100% solve its my experience only 20% cases uem replaced. good luck |
10-31-2004, 12:26 | #10 (permalink) |
Junior Member Join Date: Feb 2004 Age: 45
Member: 54237 Status: Offline Thanks Meter: 0 | there is a small component just under the pins of the phone i think it is a capacitor ,it is always broken or unsoldered with the cable ,sold it or change it men it worked for me for all the same default |
10-31-2004, 13:46 | #11 (permalink) |
Junior Member Join Date: Oct 2004 Age: 46
Member: 87011 Status: Offline Thanks Meter: 0 | i have problem with samsung c100, when i switch on the set LCD display but non of the words display ,i cannot see any words written in the screen. what can be the solution for this , pls help me |
10-31-2004, 16:06 | #13 (permalink) |
Crazy Poster Join Date: Nov 2003
Member: 43511 Status: Offline Thanks Meter: 1 | in the battery there ise 3 pins and only 2 of them are for power supply, the other is for detecting battery and voltage, check this one perhapd its damaged from phone or from battery. |
11-02-2004, 19:16 | #14 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 88402 Status: Offline Thanks Meter: 489 | soultion for avtar, its a small componant fault.but most cases u must change fuse if its in good contition also.or otherwise a very small component at near data cable pin connecting point. soultion for amitbkusb u must rebuilt imei if u don't hear any sound. thanks |
1100 charging problem | ryumahon | Nokia Hardware & Hardware Repair | 26 | 09-16-2010 15:59 |
nokia 1100 charging problem | patric | Nokia Hardware & Hardware Repair | 7 | 09-24-2009 18:19 |
1100 charging problem | jawad8305 | Nokia Hardware & Hardware Repair | 1 | 06-25-2007 08:43 |
Nokia 1100 Charging problems | ebendup | Nokia Hardware & Hardware Repair | 2 | 06-27-2006 08:15 |
1100 Charging problem | nutantopno | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 04-16-2006 16:33 |
