Old 08-13-2004, 17:00   #1 (permalink)
RAHUL12345's Avatar
Member: 59915
Thanks Meter: 4
1100 Doesnt Ring
I have 1100 which doesnot ring it only vibrates.Ringer is working goood.
pls provide some solution to fix it
thanx
Old 08-15-2004, 06:03   #2 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
check your audio IC's and check your buzzer of your phone .
you can use connceting wire for your phone buzzer and viberator interface to power your phone ringer.
bestman.
Old 08-15-2004, 06:20   #3 (permalink)
RAHUL12345's Avatar
Member: 59915
Thanks Meter: 4
hey bestman how to connect a wire to start a buzzer
pls helpppp need urgent solution. I need to give phone back.
Old 08-15-2004, 06:48   #4 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
you can connect wire to buzzer using by soldering one connecting wire to the left side soldered attachment of the buzzer to the board and next connecting wire to the right side soldered attachment of the buzzer to the board .
next operation for the viberator interface is soldering the left connecting wire from the buzzer to the left viberator interface and solder the right connecting wire from the buzzer to the right vib* interface position, solder with care.
try this. i am waiitng .
bestman.
Old 08-15-2004, 06:57   #5 (permalink)
RAHUL12345's Avatar
Member: 59915
Thanks Meter: 4
hey does this work on vibrator interface???
Will vibrator work later???
I want both ringer and vibrator ON
Old 08-17-2004, 17:51   #6 (permalink)
RAHUL12345's Avatar
Member: 59915
Thanks Meter: 4
hey plzzz help flashed the phone but no solution plzzzz its urgent
Old 08-17-2004, 18:53   #7 (permalink)
ANUCHOPRA's Avatar
Member: 73815
Thanks Meter: 4
Hi,
@ Rahul,
If Ur Phone Is Even Slightly Water Damaged Then This Will Work For Sure:
1. See Both The Ringer Pads ( Points At Pcb Where Ringer Comes In Contact) , U Ll See That A Track Is Coming Out Of Each Pad & Going Into Their Respective Resistances
2. Connect The Ringer Pads With A Very Fine Wire To The Other Side Of The Corresponding Resistance Respectiveley.
Right Now I Dont Have A Foto To Make Myself More Clear, I Hope Ull Understand What I Am Trying To Say.
Wbr,
Anuchopra.
Old 08-17-2004, 19:30   #8 (permalink)
Member: 39601
Thanks Meter: 13
Tracking
Check that pathway man on the PCB .
GoodLuck
Old 08-17-2004, 20:34   #9 (permalink)
Member: 16430
Thanks Meter: 2
bestman.
Why solder?Can use multimeter or external power supply,set power to 3v.
No good solution Mr bestman.
Old 02-28-2005, 20:49   #10 (permalink)
Member: 118880
yup medz is right. check d continuity between d various points. look at medz attached image. i found d problem with my ringer. it was a broken connection in the path way just where d buzzer is connected to d pcb.
Old 03-01-2005, 20:46   #11 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
please try this
Unggul
Old 03-03-2005, 16:05   #12 (permalink)
Member: 7468
Thanks Meter: 2
today i get one with same problem, vibrate ok but no ring.. problem was with the inductor L182... after change the problem was fix!
Old 08-04-2005, 05:12   #13 (permalink)
Member: 14287
sometimes it is software
sometimes if not solved by software do two things
1- check the digrame above mentioned ringer track
2- clean pcb especially the charging socket cuz it cuzs headset and draw a car in profile position in the main screen
i got a nokia 2600 that DOESNT ring!! SicilianBoy Universalbox 5 11-21-2006 23:22
W810i Doesnt Ring Long forzahibs Sony Ericsson 0 06-03-2006 21:30
6230 doesnt Ring!! rtcaus Nokia Hardware & Hardware Repair 3 03-10-2006 02:32
my c350 doesnt ring plz help shell Motorola P2k 6 10-26-2005 03:49
1100 Doesnt Ring Jason72 Nokia Hardware & Hardware Repair 19 10-18-2005 13:27
Page generated in 0.43850 seconds with 9 queries
