Old 05-02-2004, 00:53   #1 (permalink)
Member: 11208
Thanks Meter: 11
1100 imie ???????????4 problemm?
Hi.
Here I have one 1100 show imie ???????????4.
It fall down from table then broken like this. So is it uem dry joint problemm or flash imie problemm? All ics are glued.
When I read UEM imie with griffin it show IMEI=31153900857545
But own original IMEI=35153900857545
So why this 35 and 31 differ?
Give me advice? I need to recalculated flash imie or rehot UEM?
Thank u for attention.
Old 05-03-2004, 14:33   #2 (permalink)
Anno's Avatar
Member: 8360
Thanks Meter: 4
flash ic glued ? AMD flash >?
Try rehot uem with hot air 4-5 sec, ot change
Old 05-03-2004, 17:05   #3 (permalink)
Member: 1060
Thanks Meter: 10
it muse be 35 !
and your flash rom data has problem or flash rom it has problem
Old 05-03-2004, 17:08   #4 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,171
If all ics are glued i think you vaste your time, don't try to rehot UEM or flash or you have dead phone but if you want good solution you have to remove glue under UEM, and after i think yhou know the procedure.
Old 05-04-2004, 01:05   #5 (permalink)
Member: 11208
Thanks Meter: 11
All ics are glued. So I have no choice right now. Before I never tried to remove glued 1100 UEM,flash ic. Better to give back phone.
Thank u all of u.
Old 05-04-2004, 06:08   #6 (permalink)
mobilemafia's Avatar
Member: 7889
Thanks Meter: 7
2300 and 1100 both are s h i t
Old 05-04-2004, 07:26   #7 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
1100 2300 Flash is not glued.... but a bit tricky to remove reball and resolder....
do it only if u have experience !!
WBR
Syed
Old 05-05-2004, 19:50   #8 (permalink)
Registered User
zakirn's Avatar
Member: 7457
Thanks Meter: 21
WBR
Syed
@syed,
What trick bebind this glued ic. please let us know.!
Old 05-06-2004, 10:35   #9 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
Not trick..but experience and stable hands needed to remove Glued IC, BTW 1100,2300 Flash is NOT glued !!
WBR
Syed
Old 03-16-2005, 21:27   #10 (permalink)
.:AnOuaR:.'s Avatar
Member: 62602
Thanks Meter: 6
try log file
and see
plz help nokia 1100 imie ???????????????4 faisal_fs MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 02-24-2010 06:24
1100 imie ??????? and uem imie b5fffc5ffffffx sameenshah123 A1-Services.org 2 10-02-2008 12:56
1100 Imi ???????? j_jivan Universalbox 2 05-30-2008 23:45
Page generated in 0.17357 seconds with 9 queries
