Old 12-17-2006, 17:54   #1 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
1100 insert sim after changing sim ic,still not resolved
i have 1100 new phone that is having insert sim while sim is inside,i replace the sim ic with one from another phone that is working good,but it will accept sim and after 3 sec it will go back to insert sim. please i need help from u all.
Old 12-18-2006, 00:30   #2 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
insret sim 1100
dear i think ur fault is in simjaket ,plz chack
1 - battrey connecter if demage , change it
2 - check GND simjaket
3 - track to sim IC
ur prob will be solve 100%
regards
rashid
Old 12-18-2006, 00:43   #3 (permalink)
Steamroller's Avatar
Member: 126197
Thanks Meter: 26
Hello
Try other battery & check battery connector...
Old 12-18-2006, 00:49   #4 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
another most important thing change the battery ,
Old 12-18-2006, 01:06   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
Yes Battery Makes The Difference.
Old 12-18-2006, 01:33   #6 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
If battery Ok still Insert Sim make jumpers. Flash Phone
Old 12-18-2006, 04:04   #7 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
resolder sim socket
resolder bat connector..
remove sim ic then jump contacts with 0 ohms resistor
br
Old 12-18-2006, 04:29   #8 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
Thumbs up 1100 Insert Sim
plz try this jumpering solution It is already posted in the forum
salim
Old 12-18-2006, 23:47   #9 (permalink)
Crazy Poster
Member: 224502
Thanks Meter: 2
and pleas tel us the result to know the final solution
Old 12-19-2006, 13:38   #10 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
i remove the ic and did a wiring ,and still the same.so i used an iron file and clean the surface of the sim connector and resolder the contacts.and now the phone is okay.thanks to all my friends for their support
Old 12-19-2006, 14:26   #11 (permalink)
Member: 81501
Thanks Meter: 41
yah tested by me jumper solution...................
Old 12-19-2006, 20:26   #12 (permalink)
Member: 340898
any body help me to solve the problem that j200 mic is not working
Old 12-20-2006, 00:19   #13 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
plz go to right section i will help u
Old 02-01-2007, 22:12   #14 (permalink)
Member: 299902
Thanks Meter: 20
has any on have a solutiuon for damaged sim ic pad on a 1100 a pic will be good on how to totaly jump the ic
Old 02-01-2007, 23:30   #15 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
1100
may be it work for u
2626 insert sim after change sim ic mobilejunc Nokia Digital Core Technology 4 ( DCT-4 ) 3 09-04-2010 07:33
Help seniors, K310 Show insert Sim after Changed Power IC madni shah Sony Ericsson 1 10-22-2009 07:03
2600c keypad pro 3butons not work i change keypad ic still the 3 buttons not work lavkey Nokia Hardware & Hardware Repair 1 08-02-2008 16:49
help for N70 white screen after change sim ic chronic Nokia Hardware & Hardware Repair 1 01-22-2008 20:40
"gx20 insert sim after changing lcd" farry Sharp 0 05-03-2005 14:37
Page generated in 0.22097 seconds with 10 queries
