02-08-2008, 11:09 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 301177 Status: Offline Thanks Meter: 91 | 1100 network problem thanks |
02-08-2008, 12:07 | #2 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | U only check the phone in hardware . . . . before u check the phone in hardware u check the phone in software. OK here is u r solution . . . Try and post result. In software 1) u have write good PM file for network 2) After write PM file clear UI setting 3) And finnaly don't work this trick just heat the 3 small network switch (Below the antinna switch). Post result. |
02-12-2008, 14:27 | #12 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 629694 Status: Offline Thanks Meter: 50 | hi i dnt have pic . bro their is a resistor near hager and if u wnt 900 then from right side first resistor to bottom last point of couler and then to middle point of ist line of coupler then to antina switch point . |
nokia 1100 network problem | de brain box | Nokia Hardware & Hardware Repair | 9 | 03-05-2014 15:23 |
1100 network problem solved | ..:MumbaiGsm:.. | Nokia Hardware & Hardware Repair | 14 | 02-07-2010 14:49 |
1100 network problem | aberiya | Nokia Digital Core Technology 4 ( DCT-4 ) | 35 | 12-30-2009 09:14 |
1100 network problem | satishyathi | Nokia Hardware & Hardware Repair | 1 | 06-16-2007 07:27 |
1100 network problem | usman0000 | Nokia Digital Core Technology 4 ( DCT-4 ) | 22 | 05-29-2006 07:09 |
