Old 04-26-2005, 04:59   #1 (permalink)
yandbass's Avatar
Member: 101268
Thanks Meter: 119
1100 No Display But Has Incoming And Outgoing Calls
1100 has no display even after changing 2 to 3 good displays. The set has incoming and outging, which means all functions are ok except display. Any track solution plsssssss.
tks in advance.
The Following User Says Thank You to yandbass For This Useful Post:
Old 04-26-2005, 07:20   #2 (permalink)
Member: 101821
Thanks Meter: 5
Replace the LCD is the only ways
Old 04-26-2005, 08:23   #3 (permalink)
protocolbg's Avatar
Member: 17637
Thanks Meter: 34
If you sure that LCD is working ,
try to rehot flash interface carefully.
Old 04-26-2005, 08:49   #4 (permalink)
Azampk's Avatar
Member: 30303
Sonork: 1001579198
Thanks Meter: 17
use schematics for se lines form iterface to main lines and chek may be lines r broken
*****************Azam******************
nokia 5800 display turns off when incoming and outgoing call joelcabuyaban Nokia Hardware & Hardware Repair 62 01-13-2014 06:59
n70 no incoming and outgoing call Masudur Rahman WD2 & APE (Symbian Phones) 4 12-30-2009 03:37
n70 no incoming and outgoing call Masudur Rahman Nokia Hardware & Hardware Repair 2 09-17-2009 10:50
n70 no incoming and outgoing call Masudur Rahman Nokia Hardware & Hardware Repair 1 09-17-2009 10:25
6630 incoming and outgoing calls problem celluniversal Nokia Base Band 5 ( BB-5 ) 5 05-27-2006 09:54
Page generated in 0.24211 seconds with 8 queries
