Old 06-22-2005, 11:22   #1 (permalink)
Member: 119809
Thanks Meter: 6
1100 Not charging
Hi guys I have a Nokia 1100 that is not charging. I have tested the charging port and it is producing the normal current but the phone still is not charging. what do i do about the fault... Regards.
Old 06-22-2005, 11:25   #2 (permalink)
Member: 38922
Thanks Meter: 35
Do you get NOT CHARGING error or Nothing happens after input charger?
GreetZ
__________________________________________________ ____________
Old 06-22-2005, 11:30   #3 (permalink)
Member: 119809
Thanks Meter: 6
No Message, just not charging...
Old 06-22-2005, 11:33   #4 (permalink)
elektroserwis's Avatar
Member: 87382
Sonork: 100.96303
Thanks Meter: 6
Talking
It unites for near flash, it scants it most probably one element, which often very undergo damage observe exactly
Old 06-22-2005, 11:38   #5 (permalink)
Member: 119809
Thanks Meter: 6
don't really know which component to check right now, i have check the fuse close to the charging point on the PCB it's ok i think... but still not charging...
Old 06-22-2005, 11:40   #6 (permalink)
Member: 38922
Thanks Meter: 35
try it with change it (fuse) if not ok, Flsh it make fullreset and write PM! If not ok, > resold UEM if glued you have maybe a problem..
GreetZ
Old 06-22-2005, 11:59   #7 (permalink)
Member: 87382
Sonork: 100.96303
Thanks Meter: 6
It see in enclosure solution
The Following User Says Thank You to elektroserwis For This Useful Post:
Old 06-23-2005, 05:01   #8 (permalink)
yandbass's Avatar
Member: 101268
Thanks Meter: 120
1100 not charging
Remove R100 from 1100 circled in black in the attachment and replace it with the one in 3310. Connect one ends and leave the other ends unconnected.
The Following User Says Thank You to yandbass For This Useful Post:
Old 06-23-2005, 18:55   #9 (permalink)
GMC
GMC's Avatar
Member: 14911
Thanks Meter: 13
not working!!!!!!!!1
Old 06-23-2005, 18:57   #10 (permalink)
Member: 87382
Sonork: 100.96303
Thanks Meter: 6
Talking
not working ?????
Old 06-23-2005, 19:56   #11 (permalink)
THE-MAXIMUS's Avatar
Member: 145225
Thanks Meter: 98
Talking
this solution no working but search here
nice time
[email protected]
Old 06-23-2005, 21:41   #12 (permalink)
Member: 100195
Thanks Meter: 75
straight picture %100
3310 Board R100 x2 47k
1100 R100 47k
same
Old 06-24-2005, 17:57   #13 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
hi!
where is r100 in v.15 pcb of 1100
anyone have parts layout of it ?
w.b.r.
Old 03-23-2009, 20:07   #14 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
this is a uem fault.......................................
1100 not charging gbada Nokia Hardware & Hardware Repair 35 07-08-2012 14:48
1100 not charging and auto charging gsmsikar Nokia Hardware & Hardware Repair 11 03-23-2009 23:30
1100 not charging solution? etcelfon Nokia Hardware & Hardware Repair 4 07-30-2008 16:20
nokia 1100 not charging freshwhite Nokia Digital Core Technology 4 ( DCT-4 ) 5 07-11-2005 22:13
1100 not charging jaaja Nokia Digital Core Technology 4 ( DCT-4 ) 5 03-07-2005 04:55
Page generated in 0.22252 seconds with 10 queries
