Old 11-22-2006, 19:50   #1 (permalink)
Member: 28559
Thanks Meter: 73
1100 not charging
i have 1100 that is not charging. when charger is plugged in nothing is shown on display. fuse is ok. where do i start trouble shooting?
Old 11-22-2006, 20:52   #2 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,168
check ,
battrey connecter
change battrey
change charger
check R100
check BSI
check L261
check R200 ,
otherwise change UEM , thats last and final solution ,
The Following User Says Thank You to r a nadeem For This Useful Post:
Old 11-23-2006, 20:17   #3 (permalink)
Member: 320354
Thanks Meter: 48
normaly chane uem is ok
The Following User Says Thank You to Jeffyoh88 For This Useful Post:
Old 11-24-2006, 10:50   #4 (permalink)
Member: 393468
Thanks Meter: 15
nokia 1100 insert sim problem
Old 11-24-2006, 10:52   #5 (permalink)
Member: 393468
Thanks Meter: 15
nokia 2600 no network, charging fault & heating problem
Old 11-24-2006, 13:03   #6 (permalink)
B&B
Crazy Poster
Member: 395007
Thanks Meter: 2
almost all the time r100 or uem is the problem
The Following User Says Thank You to B&B For This Useful Post:
Old 11-24-2006, 13:15   #7 (permalink)
ics_igrec_zet's Avatar
Member: 55427
Thanks Meter: 7
For this problem:
just change UEM
For this problem:
you need to use jumper solution, small glass ic must be jumpered
For this problem:
depends what`s going hot, UEM or PA or CPU just check and post here
BR, xyz
Old 04-08-2008, 11:21   #8 (permalink)
Member: 647558
Thanks Meter: 25
10x so much bro its excillent go on>.......
Old 04-08-2008, 11:45   #9 (permalink)
Cheater -Don't Deal with him-
Member: 622382
Thanks Meter: 200
change uem ic ur problem solved
1100 not charging gbada Nokia Hardware & Hardware Repair 35 07-08-2012 15:48
1100 not charging and auto charging gsmsikar Nokia Hardware & Hardware Repair 11 03-24-2009 00:30
1100 Not charging bassboli Nokia Hardware & Hardware Repair 13 03-23-2009 21:07
1100 not charging solution? etcelfon Nokia Hardware & Hardware Repair 4 07-30-2008 17:20
1100 not charging jaaja Nokia Digital Core Technology 4 ( DCT-4 ) 5 03-07-2005 04:55
Page generated in 0.32743 seconds with 9 queries
