08-23-2007, 05:36 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | 1100 not charging Please help me what i do must be pic or in details. Thanks in advance. Muhammad Afzal Meo |
The Following User Says Thank You to meo786pk For This Useful Post: |
08-23-2007, 09:05 | #4 (permalink) |
Freak Poster Join Date: Aug 2007 Location: just learning Age: 45
Member: 560754 Status: Offline Thanks Meter: 289 | yeah thats no any solution,the only way is change the Uem ic and think use the desktop charger is a good idea!!! before i have the problem like u 2,what kind of the solution i already try but the problem still not solved,just believe it!!!!!!! |
08-23-2007, 09:16 | #5 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Quote:
IT IS VERY EASY TO CORRECT THIS KIND OF FAULT. ALL YOU NEED IS THE DIODE JUST BELOW POWER IC [CCONT] IN 3310 AND PLACE IT AS FOLLOWS. SOLDER THE PIN AT THE MARKED END TO THE LOWER END OF THE CHARGING FUSE [K] AND SOLDER THE OTHER PIN OF THE DIODE TO THE POSITIVE TERMINAL OF THE BATTERY CONNECTOR AT THE BASE. IT WORKS WELL. | |
08-24-2007, 04:36 | #8 (permalink) |
Member: 465162 Status: Offline Thanks Meter: 683 | Dear members, Thanks very much for giving me the solution. Please write in details specially if possible post the pictures because at this time i am so confuse. Thanks for help. |
1100 not charging | gbada | Nokia Hardware & Hardware Repair | 35 | 07-08-2012 14:48 |
1100 not charging and auto charging | gsmsikar | Nokia Hardware & Hardware Repair | 11 | 03-23-2009 23:30 |
1100 Not charging | bassboli | Nokia Hardware & Hardware Repair | 13 | 03-23-2009 20:07 |
1100 not charging solution? | etcelfon | Nokia Hardware & Hardware Repair | 4 | 07-30-2008 16:20 |
1100 not charging | jaaja | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 03-07-2005 04:55 |
