12-19-2006, 05:46 | #32 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Are you crasy? It's can't be 100%, because trere + 100% for R100 ( B-Temp ) + 100% for Zenner diode in plug-in line and more 900% for stupid chinese UEM-s used in 1100... so you can easy count exactly how percent your solution have... |
12-19-2006, 09:25 | #34 (permalink) |
Freak Poster Join Date: Oct 2005 Location: KM64tw Age: 37
Member: 187149 Status: Offline Sonork: 100.1611848 Thanks Meter: 33 | Probable is UEM. But, do not abort the phone. It might be a software problem. Try to write a good and full pm in the phone. I have solved a lot of nokia (10%) by writing the pm file. Try this. Best Regards from Alin! |
12-23-2006, 19:38 | #38 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | and one more soul for solve 1100 2300 no charge or not charging.... if u checked all avaliable soul then do this.. 1: get and nokia charging spare wire. ( u can get easily from electronics parts shop in 10 rupees in pak) 2: get new universel charger 3:now open ur unversel charger and put nokia charger wire on output of universal charger.and u can remove batt holder on universal charger(i hope u understand if not ask) 4: open ur 1100 or 2300 , remove fuse,coil,diode and cap,4 parts under batt conecter, 5: now jump wires from charging base to batt conetor, two charging point on batt conecter from behind, 6: safe ur conections with tape or something ...and also put tape on pcb where charging base charging points touch. 7: close ur set and power on ur mobile, nw plug ur new nokia Anti not charging charger in mobile and u will see charging bar on ur charger.. it is 100% safe and i done obve 22 phones from this soul...... just u have to be carefull with conections ,, u can use ur phone while charging too...... try and post result .. and if get any prob plz ask or anyone cant understand i can make pic soul too Form ******* dot com regards |
The Following User Says Thank You to shahjee For This Useful Post: |
12-24-2006, 05:54 | #41 (permalink) | |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 73797 Status: Offline Thanks Meter: 19 | Shahjee u have connected charging connections directly to battery connector. I think battery may be charged in this way but charging bar will be not moving. Quote:
1100 not charging | gbada | Nokia Hardware & Hardware Repair | 35 | 07-08-2012 14:48 |
1100 not charging and auto charging | gsmsikar | Nokia Hardware & Hardware Repair | 11 | 03-23-2009 23:30 |
1100 Not charging | bassboli | Nokia Hardware & Hardware Repair | 13 | 03-23-2009 20:07 |
1100 not charging solution? | etcelfon | Nokia Hardware & Hardware Repair | 4 | 07-30-2008 16:20 |
1100 not charging | jaaja | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 03-07-2005 04:55 |
