Old 04-02-2007, 09:40   #1 (permalink)
Member: 344810
Thanks Meter: 52
1100 not charging soultion (its new)
try...... this
if u checked all avaliable soul then do this..
1: get a nokia charging spare wire. ( u can get easily from electronics parts shop in 10 rupees in pak)
2: get new universel charger
3:now open ur unversel charger and put nokia charger wire on output of universal charger.and u can remove batt holder on universal charger(i hope u understand if not ask)
4: open ur 1100 or 2300 , remove fuse,coil,diode and cap,4 parts under batt conecter,
5: now jump wires from charging base to batt conetor, two charging point on batt conecter from behind,
6: safe ur conections with tape or something ...and also put tape on pcb where charging base charging points touch.
7: close ur set and power on ur mobile, nw plug ur new nokia Anti not charging charger in mobile and u will see charging bar on ur charger..
it is 100% safe and i done obve 22 phones from this soul......
just u have to be carefull with conections ,, u can use ur phone while charging too......
try and post result .. i have nt try this solution yet (i quoted this post) !!ALL CREDITS GOES TO SHAHJEE!!
The Following 2 Users Say Thank You to kashif4584 For This Useful Post:
Old 04-02-2007, 10:22   #2 (permalink)
SALNAI's Avatar
Member: 43478
Thanks Meter: 33
nice work sir ,,very nice ,,,please need some other thinks like this
br
Old 04-02-2007, 19:47   #3 (permalink)
baboom's Avatar
Member: 59935
Thanks Meter: 131
Originally Posted by kashif4584 View Post
try...... this
Just think (and keep in mind) what will happen .... when you are "off-road" WITHOUT YOUR "MODIFYED" CHARGER ..... and some1 (who don't know about your "fixed" phone) put your mobile on NORMAL Nokia charger ...
Can you try and post here the results ...
Old 04-03-2007, 05:18   #4 (permalink)
Member: 350571
Thanks Meter: 920
try...... this
hi kashif please dont mistake me
hello this is old wrong solution, all members please dont try this solution because if you try this solution, within two days pf ic will gone this is my real expereance, and i will give one advice to all members and friends, without service knowladge please dont give any solution to other, otherways first try ur self then post here,
hi members and friends please dont mistake me thank you
The Following 2 Users Say Thank You to sree krishna For This Useful Post:
Old 04-03-2007, 05:29   #5 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
and if bootleg battery is used, then u might get an explotion, since the cheap batteries dont have electronics inside to shut down charging when full.
Old 07-05-2007, 09:40   #6 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
not work in my phone
Old 07-05-2007, 09:52   #7 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
yes , wrong solution guys
Old 07-05-2007, 09:54   #8 (permalink)
JHON_DREAM's Avatar
Member: 310330
Sonork: 100.1577334
Thanks Meter: 1,449
How can it work ?
u dont read all of post here ?
brother sree krishna details explain here.u donn't read his post?
if its work it will damaged your pf .
BEST OF LUCK.
JHON.
Old 10-01-2007, 21:32   #9 (permalink)
Member: 58375
Thanks Meter: 12
stupid solution and nice wy to kill ur fone , bcoz when u supply direct voltage from charger to +ve batt these voltages go into uem , charger are mostly adjusted on 5-7 volts while battery carries 3.6v so more the voltages less the fone life , guaranteed
Old 10-02-2007, 03:04   #10 (permalink)
colonelrte's Avatar
Member: 562532
Thanks Meter: 10
bwaaaaaahhhh such a stu** solution..,. but a nice way to damage phone
Old 10-02-2007, 04:43   #11 (permalink)
.::AssAnovic.::'s Avatar
Member: 162611
Thanks Meter: 315
Not work my friend..............
Old 10-02-2007, 05:31   #12 (permalink)
bilousoft's Avatar
Member: 204662
Thanks Meter: 91
bad solution but nice to kill phone lol
Old 10-02-2007, 07:33   #13 (permalink)
RAHUL_CELLCARE's Avatar
Member: 269791
Thanks Meter: 12
very bad solution but good to damage phone
Old 10-02-2007, 08:29   #14 (permalink)
Member: 443790
Thanks Meter: 54
not work my mobile ...............thanks Q
Old 10-02-2007, 08:32   #15 (permalink)
Member: 12724
Thanks Meter: 30
Never try testing it!
1100 not charging gbada Nokia Hardware & Hardware Repair 35 07-08-2012 14:48
1100 not charging and auto charging gsmsikar Nokia Hardware & Hardware Repair 11 03-23-2009 23:30
1100 not charging solution? etcelfon Nokia Hardware & Hardware Repair 4 07-30-2008 16:20
3530 not charging soultion jignesh_1000 Nokia Hardware & Hardware Repair 0 06-25-2005 08:37
1100 not charging jaaja Nokia Digital Core Technology 4 ( DCT-4 ) 5 03-07-2005 04:55
Page generated in 0.30297 seconds with 10 queries
