1100 strange problem hi. i have a dead 1100 and flashed with twister successfully.but phone do not show local mode.init simlock and full factory set is successfull, tried with different version and erase file but still cannot power on.no display, no backlights but if try to make a call 112, you can hear the voice. it means the phone is working and the problem is display and backlights.have check the manuals but cannot find which part should be change. anyone experienced this problem? your help is highly appreciated. brgds meneleo |
thank you very much all. i have fix my problem. its only the lcd connector causing this problem.anyway, i change the whole set of lcd with frame. brgds meneleo |
Hi at all, I've an 1100 rh18 with problem on display! There are only ligths! I've try to flash it with Twister and JAF too, without results! I've flash my 1100 (Erase+Mcu+PPM+ Write PM+ Init Simlock + Full factory defaults) with version 5.60 but nothing! :( :( Any solutions pls! What I can do? Thanks in advance! :) Bye |
RH_18_1100_EErease+1100-2300 eraseFlash.bb |
try to flash it with griffin........... |
It is only lcd con. problem |
brow., aLL i know about 1100 is very sensitive in speciaLy water damage., cz this kind of phone is disposabLe., |
can anybody help me to get incoming sound in my nokia 1100 phone |
