1100 urgent in display it's shows a small car then i flash it and changed the battery connector.. .again the compliant.....please help me urgent.................... |
hi boss there is broken lines w ur unit!! |
clean the part of charger in your phone and may be all will ok your problem is that the car is chorted ( il fait un mass ) Good luck |
tell me broken lines............................................. ................... |
car please search old posts you will see the solution for solution |
change the charging connector chan ge the charging connector,tested in many phones |
Yes its handsfree pin problem change charging connector problem will solve 100%. B.r. Sunil. |
check HF socket and pcb pads related HF socket |
