Old 07-14-2006, 17:13   #1 (permalink)
Member: 217398
1100 white display
1100 white display and in ufs when connecting it shows 1st boot err
give solution i have change the cable and the box but still the same problem and the display is ok i have tested in amother set
Old 07-14-2006, 17:17   #2 (permalink)
baywalker's Avatar
Member: 260002
Thanks Meter: 8
please show the complete log or screen shot.
the possible solution is to reheat flash IC and the CPU.
B.R.
Old 07-14-2006, 17:28   #3 (permalink)
Member: 217398
1100 white display
it just simple says ist boot err
Old 07-14-2006, 17:35   #4 (permalink)
baywalker's Avatar
Member: 260002
Thanks Meter: 8
when you connect the ufs can you see local mode in the screen?
if not try to check the connection of the interface.
if the connection is ok reheat flash IC and the UEM.
good luck.
Old 07-15-2006, 22:53   #5 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
first chek the battery terminals.......... if okay then connect it with ufs........ erase flash .......... then make it full flash with new version ........ write pm..........ui settings.......
okay.....
Old 07-17-2006, 17:24   #6 (permalink)
Member: 93214
Thanks Meter: 18
remove mother board from set and connect ufs cable and flash..it will work
white display 1100 chris2007 HWK 2 08-21-2010 17:01
100% working solution for w850 flash ok white or blinking white display dreameye Sony Ericsson Hardware Repair 0 06-11-2009 15:49
No display-3310 / white display-6600 / blue screen-6085 Jayasinghe Nokia Hardware & Hardware Repair 0 09-08-2008 04:25
w 550i white display, where is display IC seeta Sony Ericsson Hardware Repair 5 06-30-2008 14:03
white display 1100 chris2007 MT-BOX 6 11-09-2007 18:38
Page generated in 0.28991 seconds with 8 queries
