1110,1112,1600 etc. LCD light solution Hi mates and aslamualikum. after this i want to help u if ur 1110,1112,1600 or any other set like this and u can solve its lcd light problem by using my solution if u need u need no light ic in this procedure http://www.*******.com/image_preview.php?i=5&u=11449950 |
dear abdul4gsm, on ur jumper solution, u r shorting the VFLASH 2.8v to VBAT. is this cause any problem? |
tested on nokia 1600 with no light at all 100 % driver problem, but jumper solution tested, NOT WORKING, no light at all anyone else ? |
Nothing to do any silly Idea change only light IC |
tested on 1112. solution does not work!.. |
I Will Say Change Light Ic..............is The Best |
1600 light solution 2 Attachment(s) bro here is tested solution for 1600 light.also both leds will work.check solution.if any problem? pm me . |
Yes It's work... I always do this sol.. |
What I mean is that the lighting is not extinguished |
The solution is incomplete, but thank you |
first u need to chk the vbat connection if its still have a connection if there is, then the jai2008 sol. is write but if dont then go for abdul4gsm....tested by me many times........so last thing u need to read sytimatic diagram b4 applying different trics and trace the connection hope it help to all.... br opaw |
1 Attachment(s) this sol work 100 % in 2310 . 1 remov old chip and chek V bat 2 add LTYN chip from old samsung LCD |
