12-20-2009, 05:27 | #1 (permalink) |
Crazy Poster Join Date: Dec 2009 Location: HOME
Member: 1177643 Status: Offline Thanks Meter: 27 | 1110.1200.1650... any probleb contact me. 1100. 1110. 1600. 2310. 1650. 1200.1208. 1202. 1661. 3100. 6600. 7610. and other papular model. my contact no. xxxxxxxxxxxxx [email protected] Last edited by ..::ArchitRaj::..; 02-03-2010 at 03:25. Reason: phone number removed |
The Following 2 Users Say Thank You to A.M.Amjad For This Useful Post: |
12-20-2009, 13:34 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | '''''''''''''''''''''''''''''''''''''''' http://forum.gsmhosting.com/vbb/showthread.php?t=884016 |
12-20-2009, 14:52 | #9 (permalink) |
Member: 1177643 Status: Offline Thanks Meter: 27 | 1. change speaker 2. change two resistance near the vibrator or shart four point. Last edited by A.M.Amjad; 12-20-2009 at 14:58. |
The Following User Says Thank You to A.M.Amjad For This Useful Post: |
12-21-2009, 09:11 | #10 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 403881 Status: Offline Thanks Meter: 80 | 1200 contact service , when connected to software shows local mode. here is flashing log Getting MCU ID MCU ID: 0x2292 FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Scanning ini files... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x72888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: d9 Loader is ready... P-key nokia module version 01.02 MSID: 84A383BDAE098CFE506D54A0C8 MSID decoded: 3E4EBAE9000D73D9A9000000 FAID: F41CD07680EB917C1F38B61B Operation took 0 minutes 10 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 37 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 21 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80aa Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x72888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: d9 Loader is ready... P-key nokia module version 01.02 MSID: 840307CEA891E66114F33F10B1 MSID decoded: 3E4EBAE9000D73D9AA000000 FAID: EBD234BAED825BEB86E2D0F9 Operation took 0 minutes 14 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 12 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80aa Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x72888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: d9 Loader is ready... P-key nokia module version 01.02 MSID: 84BD9C6A76823E11EC644285C7 MSID decoded: 3E4EBAE9000D73D9A8000000 FAID: DEA48D5624053A6C53A5C56D Operation took 0 minutes 12 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 1 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 2 minutes 35 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! Any solution? Regards, |
12-21-2009, 17:38 | #11 (permalink) |
Member: 1177643 Status: Offline Thanks Meter: 27 | 1. software 1. software whith jaf flasher. 2. if soft compleat but set no power on. 2. hardware. 1. remove tow compstar back of battry tarminal. 2. replace or remove four point resistance near the uem. |
12-21-2009, 19:10 | #12 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1150643 Status: Offline Thanks Meter: 40 | 1202 water damage, dead. try to check the power supply using the current consumption of 0.2 A. check all the normal box wear. what think about the problem? please solution. |
The Following User Says Thank You to mayor_NY For This Useful Post: |
12-22-2009, 17:15 | #13 (permalink) |
Member: 1177643 Status: Offline Thanks Meter: 27 | brother this is hardware problem. 1. cleen bord whith ctc. 2. heat uem and ram. this is final solution brother. |
1100/1110/1200/1600/1650...dead solution is exe..... | rumenshom | Nokia Hardware & Hardware Repair | 39 | 11-23-2010 05:57 |
What box supported nokia copy 1110 1200 1650 etc... | djibrilcoulibal | Chinese Models & Cloned Phones | 2 | 03-11-2010 06:15 |
1110/1600/1650/1200 strange problem | SAMEER525K | Nokia Hardware & Hardware Repair | 1 | 11-15-2009 06:20 |
1110 1600 1650 1200 only clear board pic | waqas_as | Nokia Hardware & Hardware Repair | 0 | 02-02-2009 10:27 |
