Old 06-14-2008, 08:43   #1 (permalink)
Member: 138236
Thanks Meter: 10
Red face 1110 and 1208 charging.
I have 1110 and 1208 with charging fault.
When i insert charger no any message show on display.
but battery is not charge.
I replaced charging jack but same.
Anybody help plz.
The Following User Says Thank You to rashidj For This Useful Post:
Old 06-14-2008, 10:29   #2 (permalink)
ARS.Rehman's Avatar
Member: 491455
Sonork: On My LAB
Thanks Meter: 296
Same problem with 1110.
when connect charger not responce.
Help please.
Old 06-14-2008, 14:26   #3 (permalink)
AAS.Akbar's Avatar
Member: 750628
Thanks Meter: 55
Rong Post Sorry............................................. .......................!
Old 11-10-2008, 15:31   #4 (permalink)
Member: 201595
Sonork: 100.1641255
for charge no response remove charging fuse 100000% working it's a crystal ic with 4 pin near charging jack
Old 11-10-2008, 16:17   #5 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Here is 1200,1208 chirging che this
The Following 6 Users Say Thank You to Shantobhai For This Useful Post:
Old 12-02-2008, 05:40   #6 (permalink)
Member: 306530
Thanks Meter: 16
yeah... it works in my case... charging jack ok.. try solution by Shantobhai, it works... thanks
The Following User Says Thank You to VEX-CELL For This Useful Post:
Old 12-02-2008, 06:09   #7 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
change 4.7k100% solve uer problem.... good luck
The Following 2 Users Say Thank You to ^^^RAVI SOOD^^^ For This Useful Post:
Old 12-02-2008, 15:07   #8 (permalink)
Member: 350629
Thanks Meter: 18
change or remove charging ic
Old 04-23-2009, 15:57   #9 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
the solution is not working for me plzzzz help
Old 04-23-2009, 18:12   #10 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
1st check the charge Zenger ic
The Following User Says Thank You to azez.sd For This Useful Post:
Old 05-27-2009, 11:49   #11 (permalink)
yahia ali's Avatar
Member: 206173
Thanks Meter: 169
do this it is 100p100 working tested by me
File Type: gif 1200-1208%20power charging jumpers.gif (139.9 KB, 234 views)
The Following 2 Users Say Thank You to yahia ali For This Useful Post:
Old 05-27-2009, 11:56   #12 (permalink)
ticksjarub's Avatar
Member: 534932
Thanks Meter: 49
i have also here, i try those tricks. but thanks men.
Old 05-27-2009, 13:15   #13 (permalink)
javedsf's Avatar
Member: 811013
Sonork: 03468717163
Thanks Meter: 744
thnks okokokpokkmok
Old 06-01-2009, 10:55   #14 (permalink)
Member: 1043511
Thanks Meter: 28
remove charging ic and replace near the charging ic capictor
1110,1600,6030 Local or test mode,contact service,insert sim,and not charging. cgsm Nokia Hardware & Hardware Repair 112 11-03-2010 21:16
Nokia 1112,1110,1200,1208,1202,1203, Lcd going Off after Few seconds 100000% Solution madni shah Nokia Digital Core Technology 4 ( DCT-4 ) 3 04-28-2010 16:02
New Nokia Hardware Solution 1110 1200 1208 1209 ETC john.pallan Nokia Digital Core Technology 4 ( DCT-4 ) 2 05-18-2009 17:11
new 1110,1600,6030 Local or test mode,contact service,insert sim,and not charging arshad_ali77 Nokia Hardware & Hardware Repair 25 07-11-2008 17:51
Page generated in 0.21233 seconds with 10 queries
