1110, 2600, 1600 sim not valid hello friends I have 1110, 2600, 1600. three nokia sets as problems "sim not valid" i changed soft, ui settings, in my ufs3 box but still same complint, i checked ime number is ok. i gussed one problem sim reader ground to one pin short i disconnected shortage one pf . but same problem HOW TO SOLVE THIS PROBLEM kindly help me friends URGENT THANKING U |
1100 promble imie ?????????????? one soltuion but no work all set 2:try to flash the phone v 6.64 mcu ppm 3:write patch(use 6.64 imei repair cep serv) 4:write imei(use orginal imei) 5hone now contact service..click to phone info and full flash 6.64V mcu ppm 5:ui settings 6hone is ok.........good luck............ |
Best Solution Is To Change Uem:) |
say full about patching IMIE . hou can i use patch & where i find that patch? it works with ufs3 HWK ? |
1110 Quote:
MCU Sw: V 5.04 08-06-06 RH-70 (c) NMP PPM Sw: V 5.04 08-06-06 RH-70 (c) NMP AA Prd.Cd: 0529570 Bpr.Cd: 0520758 Pro.Sn: KGN153933 HW : 0502 PCI : UEM : 1314 UPP : 8705 RFIC : DSP : P05w06.v34 LCD : INLUX:MILS05 IMEI : 359767-00-xxxxxxxx SLconf: 234-00-00300000000 SLprof: 000000000000000-2 SLvar : 00003597670095114800 SLaux : 00023131 Provider: Virgin (some 3510i);United Kingdom #pw+ 958 812 674 630 520 +1# #pw+ 845 551 461 357 564 +2# #pw+ 848 551 063 607 766 +3# #pw+ 008 093 023 662 502 +4# #pw+ 127 934 545 531 647 +5# #pw+ 042 213 760 004 622 +6# #pw+ 994 302 612 275 714 +7# |
1 Attachment(s) brother check it for 1110 |
1110 imei corect but gives sim not valid unlock with tornado ,jaf no think flash it & still same . |
Hi m8 you have 1110, 2600, 1600. three nokia sets as problems "sim not valid all these Nokias phone are working b4 or have you tried to to put an other simcards can you explain if that mean None of any simcard accepted!! cause some times the best way to unlock thse phone Via ..read codes use UFS to get the right unlocking codes!! Best of luck m8 |
read code via ufs and discounect phone from ufs put sim card in it power on message appear SIM NOT VALID then put #pw+.................+1# phone restriction off.....BEST OF LUCK....for me always work |
Your phone ( instance) v.4.04 and after unlock phone say SIM NOT VALID, you writhe flash take down v.3.42, and then unlock. Work 100 % ! High version have problem with unlock even with code #pw*.............+..# but if your phone is 3.42 not problem and codes unlock |
can anyone send me the patch file @[email protected] |
Ismail Khan sim not valid is imei????????? problem change UEM get write RPL unlock full UI factory defoult if your phone imei is good so plz flash again and write an a fresh copy of full pm unlock full UI factory defoult ISMAIL KHAN |
