Old 08-24-2006, 08:44   #1 (permalink)
Registered User
Member: 76882
Thanks Meter: 55
1110, 2600, 1600 sim not valid
hello friends
I have 1110, 2600, 1600. three nokia sets as problems "sim not valid"
i changed soft, ui settings, in my ufs3 box but still same complint, i checked ime number is ok. i gussed one problem sim reader ground to one pin short
i disconnected shortage one pf . but same problem HOW TO SOLVE THIS PROBLEM kindly help me friends URGENT
THANKING U
The Following 3 Users Say Thank You to kiran For This Useful Post:
Old 08-24-2006, 09:05   #2 (permalink)
Member: 316371
Thanks Meter: 44
1100 promble imie ?????????????? one soltuion but no work all set
2:try to flash the phone v 6.64 mcu ppm
3:write patch(use 6.64 imei repair cep serv)
4:write imei(use orginal imei)
5hone now contact service..click to phone info and full flash 6.64V mcu ppm
5:ui settings
6hone is ok.........good luck............
The Following 3 Users Say Thank You to chandno12003 For This Useful Post:
Old 08-24-2006, 09:24   #3 (permalink)
Crazy Poster
Member: 201598
Thanks Meter: 3
Best Solution Is To Change Uem
The Following 2 Users Say Thank You to franzGSM For This Useful Post:
Old 08-24-2006, 09:32   #4 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,444
say full about patching IMIE . hou can i use patch & where i find that patch?
it works with ufs3 HWK ?
The Following User Says Thank You to sneha For This Useful Post:
Old 08-24-2006, 09:49   #5 (permalink)
CHAPRAN's Avatar
Member: 31906
Thanks Meter: 101
1110
5:ui settings
what is it cant unlock,help...
MCU Sw: V 5.04 08-06-06 RH-70 (c) NMP
PPM Sw: V 5.04 08-06-06 RH-70 (c) NMP AA
Prd.Cd: 0529570
Bpr.Cd: 0520758
Pro.Sn: KGN153933
HW : 0502
PCI :
UEM : 1314
UPP : 8705
RFIC :
DSP : P05w06.v34
LCD : INLUX:MILS05
IMEI : 359767-00-xxxxxxxx
SLconf: 234-00-00300000000
SLprof: 000000000000000-2
SLvar : 00003597670095114800
SLaux : 00023131
Provider: Virgin (some 3510i);United Kingdom
#pw+ 958 812 674 630 520 +1#
#pw+ 845 551 461 357 564 +2#
#pw+ 848 551 063 607 766 +3#
#pw+ 008 093 023 662 502 +4#
#pw+ 127 934 545 531 647 +5#
#pw+ 042 213 760 004 622 +6#
#pw+ 994 302 612 275 714 +7#
The Following User Says Thank You to CHAPRAN For This Useful Post:
Old 08-24-2006, 11:58   #6 (permalink)
muddsar's Avatar
Member: 227361
Thanks Meter: 28
brother check it for 1110
The Following User Says Thank You to muddsar For This Useful Post:
Old 08-24-2006, 23:08   #7 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
this is for insert sim not for sim not valid................ if the imei is ??????????????? like this then this not work...........
The Following User Says Thank You to c_ahmad79 For This Useful Post:
Old 08-25-2006, 17:47   #8 (permalink)
Member: 300911
Thanks Meter: 3
1110 imei corect but gives sim not valid unlock with tornado ,jaf no think flash it & still same .
The Following User Says Thank You to no1mobiles For This Useful Post:
Old 08-25-2006, 21:52   #9 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
with which version did you flash.............. flash it with some different version........ and unlock if it still remain the same ..... unlock it manually........
Old 08-25-2006, 21:59   #10 (permalink)
Jamal's Avatar
Member: 2845
Thanks Meter: 9
Originally Posted by kiran View Post
hello friends
THANKING U
Hi m8
you have 1110, 2600, 1600. three nokia sets as problems "sim not valid all these Nokias phone are working b4 or have you tried to to put an other simcards can you explain if that mean None of any simcard accepted!! cause some times the best way to unlock thse phone Via ..read codes use UFS to get the right unlocking codes!!
Best of luck m8
The Following User Says Thank You to Jamal For This Useful Post:
Old 08-25-2006, 22:36   #11 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
Thanks Meter: 137
read code via ufs and discounect phone from ufs put sim card in it power on message appear SIM NOT VALID then put #pw+.................+1# phone restriction off.....BEST OF LUCK....for me always work
The Following User Says Thank You to irfaN_vu For This Useful Post:
Old 08-28-2006, 19:56   #12 (permalink)
Member: 23786
Thanks Meter: 15
Your phone ( instance) v.4.04 and after unlock phone say SIM NOT VALID, you writhe flash take down v.3.42, and then unlock. Work 100 % !
High version have problem with unlock even with code #pw*.............+..# but if your phone is 3.42 not problem and codes unlock
The Following User Says Thank You to vmobil For This Useful Post:
Old 08-30-2006, 15:24   #13 (permalink)
pawansingh's Avatar
Member: 306087
Thanks Meter: 24
can anyone send me the patch file @[email protected]
The Following User Says Thank You to pawansingh For This Useful Post:
Old 08-30-2006, 16:44   #14 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
patch file for which model..............................?
Old 08-30-2006, 21:44   #15 (permalink)
tommobil2005's Avatar
Member: 232662
Thanks Meter: 58
Ismail Khan
sim not valid
is imei????????? problem change UEM get write RPL unlock full UI factory defoult
if your phone imei is good so plz flash again and write an a fresh copy of full pm unlock full UI
factory defoult
ISMAIL KHAN
The Following User Says Thank You to tommobil2005 For This Useful Post:
1600 sim not valid??????? GSMLover2010 Universalbox 20 11-27-2009 09:52
1600 sim not valid imei ok unlock with jaf,ufs,fusion still same zargar322 Nokia Hardware & Hardware Repair 18 03-15-2008 22:39
1600 sim not valid? bavesore Nokia Digital Core Technology 4 ( DCT-4 ) 12 04-10-2007 22:35
1600 sim not valid ijogo Nokia Hardware & Hardware Repair 10 02-20-2007 08:46
1600 sim not valid manyosa Nokia Hardware & Hardware Repair 11 08-04-2006 20:46
Page generated in 0.51232 seconds with 9 queries
