Old 11-13-2008, 15:41   #1 (permalink)
dapinderjit's Avatar
Member: 145082
Thanks Meter: 798
Question 1110 blinks continously if switched on
nokia 1110 water damaged
no short circuit
blinks continously if power is switched
how could the problem be resolved ??
thanks in advance
regards
dapinder
Old 11-13-2008, 16:41   #2 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
Flash it and ur prob. will be solved buddy
Old 11-13-2008, 17:09   #3 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
Arrow 1100 Blinks Continously If Power Is Switched
no short circuit
thanks in advance
regards
dapinder
Dear Brother First Of All Flash It. If Your Problam Is Not Clear.
Then Open Your Mobile And Wash The Full Circuit . Then Flash It Back With The Latest Version........Thanks
The Following 3 Users Say Thank You to khisrow For This Useful Post:
Old 11-13-2008, 17:21   #4 (permalink)
Member: 145082
Thanks Meter: 798
will flash it and post result by tommorow evening
thanks for instant reply
regards
dapinder
Old 11-13-2008, 17:26   #5 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
this prob persist due to water lock so first cleannnnnnnn well using good cleaner
sp
Old 11-13-2008, 17:29   #6 (permalink)
Member: 877138
Thanks Meter: 10
100% saluion and tested
no short circuit
thanks in advance
regards
dapinder
brother atech the two uper sides of ressistances near lcd jack if lcd appear wire them .Tested many time
Old 11-13-2008, 19:04   #7 (permalink)
Member: 145082
Thanks Meter: 798
shakeel
i cann't get you
please tell me in detail
am i supossed to make jumper with the resistance
please explain it
regards
dapinder
Old 11-13-2008, 19:28   #8 (permalink)
Member: 145082
Thanks Meter: 798
sakheel
if i short the resistance upper parts with each other
the phone do not power on !!!
Old 11-13-2008, 19:44   #9 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
sakheel
" circuit says if u do that the set wont power off then u hav to remove that work & magic will begin again, now comes to ur problem if u mean that it blinks only when switched on & doesnt get off when power off the switched then go for flashing, thanx"
Old 11-14-2008, 07:43   #10 (permalink)
Member: 665757
Sonork: 100.1606890
Thanks Meter: 15
flash it by hwk micro 100% solved
Old 11-14-2008, 07:49   #11 (permalink)
Member: 505752
Sonork: 1611502:zubair
Thanks Meter: 33
just flash with jaf ur problem solve
Old 11-14-2008, 08:56   #12 (permalink)
Member: 877138
Thanks Meter: 10
ok lets work
sakheel
ok lets work step by step
1- Wash the set
2-Flash the set
3-Check the continuty with jack also resistances
4-Check continuty with the lower down capecter and diod with jack and resistance.
5-Check to jack carefully
Now ur set will be ok .
Last edited by shakeelzaffar; 11-14-2008 at 09:00. Reason: i have some pics all this method but not uploading
Old 11-14-2008, 12:38   #13 (permalink)
Member: 145082
Thanks Meter: 798
phone is alive now
thanks to all
for your kind support
thanks again...
Old 11-14-2008, 13:18   #14 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Simply flash u r set.
Old 11-15-2008, 21:50   #15 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
1110 displa blinks
Brother not flash it because its water damage so that is hardware prob first u check your lcd connector if not check light ic and nearest parts may be see water here if not just rehot upp your problem solved
**HELP** Samsung S399 showing UART DLOAD if switched on.. joy4u Various CDMA/TDMA Cell Phones 3 09-25-2009 14:46
Motorola L7>> Can't Be Charger If Phone Switch On... Roxy_Selindo Motorola Hardware Repair 0 03-28-2008 14:10
SE K500i blinking lcd if sim inserted :s janar_jk Sony Ericsson Hardware Repair 0 12-01-2005 07:50
T65 switch on ... switch off ... switch on ... switch ....... MiSi3k Sony Ericsson 8 08-17-2003 00:45
788 flashed with 788e SHX blinks when switch on McSty Old Ericsson Phones & Sony Phones 1 04-11-2000 20:24
Page generated in 0.29490 seconds with 9 queries
