07-23-2008, 05:10 | #2 (permalink) |
No Life Poster Join Date: Jul 2006 Location: UK Age: 45
Member: 318277 Status: Offline Thanks Meter: 92 | Mate This waz discussed a lot in the forum ..pls use search button.. Any way its not software issue..It happens due to to the over heating...coz Sim IC is near UEm n UPP... Solution - try to heat the PCB from the other side of the UEM n UPP Post result Br |
07-23-2008, 06:05 | #6 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, 1st remove sim ic and then see contact service problem solved or not? if not then this problem comes from uem heat uem from the other side of the pcb post your reult |
N70 dead after replacing retu ic | luyanda | Nokia Hardware & Hardware Repair | 2 | 02-27-2010 11:48 |
1110 gone dead while replacing keypad ic | Vicky Matharu | Nokia Hardware & Hardware Repair | 1 | 02-23-2010 06:07 |
1110 contact service by changing sim ic | Options Media | Nokia Hardware & Hardware Repair | 2 | 07-29-2009 15:25 |
1110 contact service after chang sim ic | Elias Khan | Nokia Hardware & Hardware Repair | 1 | 06-13-2009 13:57 |
3110 conact service after chage sim ic | amit agrawal | Nokia Hardware & Hardware Repair | 4 | 08-27-2008 17:31 |
