1110 flashing error Getting MCU ID MCU ID: 0x2201 FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_06.400 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_06.40aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh700_nai6.40aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_06.400 Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2A0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: c6 Loader is ready... P-key nokia module version 01.02 MSID: 8466C72D5ABA8CDF1E4B13F9FD MSID decoded: 3E4EBAE9004D5C33A9000000 FAID: AEE2D7491756906943EC9173 Operation took 0 minutes 11 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013BFFFF... Erasing area: 013C0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 30 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 12 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_06.40aa Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2A0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: c6 Loader is ready... P-key nokia module version 01.02 MSID: 8466C72D5ABA8CDF1E4B13F9FD MSID decoded: 3E4EBAE9004D5C33A9000000 FAID: AEE2D7491756906943EC9173 Operation took 0 minutes 11 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 12 seconds... Writing... Error cmd: 14! Addr: 01234000 please help |
do full erase and fullflash after with the latest firmware |
bro, try to clean pcb as well and heat by lamp minimum 15 mins and then try to flash again post your result |
thanks brothers for help me its ok by just full erase & re flash thanks again.:D:):cool:;) THANKS |
can anyone pleae tell me step by step how to full erase please i am new to all this |
