Old 07-24-2008, 15:11   #1 (permalink)
lavlesh jain's Avatar
Member: 666813
Thanks Meter: 88
1110 flashing error
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_06.400
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_06.40aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh700_nai6.40aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Backing up PM Field 208 as RPL...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_06.400
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E2A0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: c6
Loader is ready...
MSID: 8466C72D5ABA8CDF1E4B13F9FD
MSID decoded: 3E4EBAE9004D5C33A9000000
FAID: AEE2D7491756906943EC9173
Operation took 0 minutes 11 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 30 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 12 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_06.40aa
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Writing...
Error cmd: 14!
Addr: 01234000
please help
Old 07-24-2008, 15:17   #2 (permalink)
westgold's Avatar
Member: 734668
Thanks Meter: 83
do full erase and fullflash after with the latest firmware
The Following User Says Thank You to westgold For This Useful Post:
Old 07-24-2008, 15:17   #3 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
bro,
try to clean pcb as well and heat by lamp minimum 15 mins
and then try to flash again
post your result
The Following User Says Thank You to jimm07ct For This Useful Post:
Old 07-24-2008, 15:41   #4 (permalink)
Member: 666813
Thanks Meter: 88
thanks brothers for help me its ok by just full erase & re flash thanks again. THANKS
Old 08-13-2008, 14:37   #5 (permalink)
Member: 752352
Thanks Meter: 3
can anyone pleae tell me step by step how to full erase please i am new to all this
1110 flash error Parminder Singh Nokia Hardware & Hardware Repair 9 05-07-2008 13:06
Nokia 1110 flash error zakir375 Nokia Hardware & Hardware Repair 0 11-28-2007 14:14
nokia 1110 flash error ayaz ali Nokia Hardware & Hardware Repair 8 02-18-2007 06:20
Page generated in 0.22469 seconds with 8 queries
